I'm not far from you in Baton Rouge. I'm tempted to wash mine anyway after this weekend. I'm headed to my hunting camp so it'll be a really lost cause if I do it before then.
Do it, have it clean for the ride. That way you can see just how much fun you have while you're there[emoji106] I'm heading to Destin this weekend for a much needed vacation and I'm washing the truck today or tomorrow afternoon, gonna get all bugged up between here and there so not looking forward to that
Took off my OEM running boards and ordered AMP power steps the other day. I got a hole in my pocket now :')
Getting ready to install 28 inches light bar in bull guard anyone know of any holes in firewall to pass wires thru.
https://www.amazon.com/gp/aw/d/B00XEGCM2G/ref=yo_ii_img
I used the one that the hood latch cable runs through. Plenty of room for my wires.
thanks
Made a flag pole to fit in my hitch flag holder, and installed DuraFlap mud guards all around today. Oh, and finally put license plates on it and got rid of the paper tags and that hideous dealer plate frame.
Good choice tho. You're going to love them.
Sent from my iPhone 6+
I hope so!! I dont know when it will arrive though, the shop could not give an estimate on arrival time but sometime in 2 weeks they said. :(
They're great steps! Especially if you go off road. That's the reason I went with mine.
I got it because of the oem ones are rusting through one canadian winter.... Professional grade for ya
Gotta love it lmao! The AMP steps should do fine. A few days after I had mine installed I went through quite a few mud holes since it was hunting season and they're holding up fine
Installed an HID kit. I'm glad to finally be rid of the ugly yellow stock lights!
How many watts is that?? How much did it come to?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
