Got her washed up finally!
I wish I could! It's been raining here in Louisiana for about 2 months everyday straight!
Sold It! Moving back into an SUV.
'14 K1500 6.2L Denali w/9,300 miles, listed for 1-day, received numerous inquiries and sold it $50.950 cash deal.
Enjoyed being here in the forum and the contributions from some of its members who assisted by answering questions I had.
Edited by rewillia
What high, low, fogs are you running?
High and low beams are 6000K HIDs from strictlyhid.com and the dogs are 6000K LED from VLED.com
Which SUV did you go with? Pics?
I've still washed mine 2 or 3 times lol. Just quick washes to get some of the larger amounts of dirt off. I'm down in NOLA
purchased - a few weeks ago...
Justin%20Sonoma%20Red%20Metalic_zpsojlby
installed RC 2.5 friday night and mounted tires Sat morning.
removed n-fab bars - going to sell on craigslist...
added husky x-act floor mats
rear husky full weatherbeater
and husky rear underseat storage
What? Lol good for you! That guy could have bought a new '15 for that.
Husky is a great choice! I've got weather beaters all around and the rear storage. Not a single complaint.
Edited by crafferty
now im on the hunt for a decent tool kit that will fit in the underseat storage area...anyone recommend anything / brand?
I have two 5 piece Craftsman wrench sets that come in a roll up canvas bag. These I keep in my drivers door along with a LED flashlight and digital tire pressure gauge. Under the rear seat I have two cheap-o tool kits from Advance Auto Parts. They retail for $30 but if you keep an eye on ads you can pick them up for $10. Then a cheap set of screw drivers. After that mine is filled with ammo and paper targets for the range.
http://shop.advanceautoparts.com/p/toolworks-89-pc-socket-set-tw218/9010619-P?navigationPath=L1*14924%7CL2*15040#
http://shop.advanceautoparts.com/p/toolworks-53-pc-socket-and-bit-set-tw203/9010394-P?navigationPath=L1*14924%7CL2*15040#
Washed the outside, pressured washed the shit out of the under carriage in prep for undercoating, and detailed the inside.
Then I installed my Husky front & rear floorliners and the du-ha storage, and loaded it up with tools and equipment.
Tomorrow = getting Borla ATAK installed and the Airaid Jr. Kit.
Next up... trying to find a lift kit and tires that fit on my stock rims AND stick out far enough to look good with bushwackers.
:thumbs:
I'm not far from you in Baton Rouge. I'm tempted to wash mine anyway after this weekend. I'm headed to my hunting camp so it'll be a really lost cause if I do it before then.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
