This is what it looks like all buttoned up.
Looks good!! Since you have chrome grille, it does not look so eye sore with the shiny glass behind it! Which light bar is it??
Bought off amazon. Figured for the money it was worth trying.
http://www.amazon.com/gp/aw/d/B00P8ZAU1Q#
Is it as bright as you think it claims? 18000lm.... LOL
It's pretty bright, will have to see what it looks like when it's dark out.
Platidipped my rims dark bronze, pictures dont show the bronze very well.
Bronze plastidip
Bronze plastidip
Bronze plastidip
Bronze plastidip
That turned out real nice! I just did mine over the weekend in black. Haven't put them back on the truck yet.
Thanks so glad i spent the time to do it this weekend then have a-hole hit me today. added some nice texture to the back end of the truck. thank god for the oversized tires i had on there or else that wouldve been ripped to shreds.
Going for the junker look
Big gash
The other week something happened that made em glad I have 18s instead of 22s or even 20s. I was on a road in front of Walmart on the completely other side on the back end of the parking lot and someone almost ran into me going the other way So the only thing I could do was swerve and the front right tire hit the curb. Luckily having 18s I didn't get any damage on the rims, just curb rash on the tire.
I had close call too, although it was my own fault. Was backing into a driveway and didn't see a fire hydrant and the front end swung into it. Luckily the side bolt thing hit the side of the tire instead of rim or a body panel. Never been so happy to see a scrape on the tire!
I've been working on doing my "spring clean" of the truck, although my schedule and the weather have not been cooperating. So I far I've clay barred it, and polish/glaze/waxed the box tailgate and hood. Tomorrow I should have time to finish that and then it's on to glass/plastics and interior.
I plastidipped my factory 18's charcoal grey, but they're not on the truck yet. I think I'll aslo dip the bowties to match.
Added these bad boys to cover up the airbag warning stickers on the sun visor. Picture isnt the best but it looks amazing in persone438b21c79f4935cc22bc1a6c88a8f7c.jpg
I really like the look of that. Where'd you get it?
All cleaned up today, went to the park for some nice sunset pictures! I think this looks like a picture straight out of GMC commercial.....
I had them made. They'll tire in with the sill plates when I get them again
I switched out the white center high mount lights to LED. Is the only way to have them come on is with the button on the inside of the truck? I was hoping the light would come on when unlocking the truck.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
