so i did a thing
Gloss black Bumpershellz. Front bumper now a color matched gloss black.
I am EXTREMELY Satisfied and would order again in a heartbeat. items arrived in perfect shape, perfectly packed and are a damn good match to the factory black.
enjoy the pics fellas (dont mind the HID warmup in the once pic lol- promise theyre 5000k)
Bumpershellz looks great I was on the fence about getting one. Did you get the rear cover also?
Installed the Bakflip MX4 today. Pretty easy to install. Will get the first big test tomorrow since it's supposed to rain for the next 24+ hours and I'll be hauling stuff an hour plus on the interstate.
Let us know how it does. My Bakflip is about 90% water tight. I actually think it is the way the bed is as opposed to the cover but it does not stay fully dry ( pouring, car wash ) etc
Edited by Doobs41378
Well, I haven't hauled anything but it did rain like crazy overnight. I checked this morning and had a little water inside the bed but not too much. It was on the driver side near the cab of the truck. I'm not sure where it was coming in from, but I was parked up a slight incline with the rear end higher than the front...oh, and I haven't installed the drain tubes yet either. I figured I'd see how things go before I did that. I know some folks on here have passed on installing them too. If I continue to see water inside, I might give them a shot. I do like the cover though, love that it sits flush and that i can open and close the tailgate with the cover down all the way.
So closing the tailgate with the cover closed doesn't affect any seals at the end of the cover?
The MX4 allows you to close it with the cover shut already. It's one of the only Bakflip's that allows for that.
From page 5 of the installation manual: http://bakindustries.com/files/pdf/2016/bakflip-mx4-installation-instructions_4-17-2016.pdf
TO CLOSE THE TAILGATE PANEL
WARNING – to avoid damage, always shut tailgate before closing cover. DO NOT shut your tailgate when the rear panel of your cover is closed.
EXCEPTION - BAKFlip MX4 offer’s a universal tailgate seal which allows the tailgate to close with the cover up or down.
They need to hurry up with a 2016 version! I would buy one in a heartbeat.
Will replacing the reverse lights, license plate lights, and box lights cause any "light failure" lights? Was thinking of grabbing this set:
http://www.ebay.com/itm/6pc-2016-Silverado-Xenon-White-Reverse-Cargo-License-Plate-Lights-Bulbs-Combo-/222190367568?hash=item33bb93f350:g:0pAAAOSwMsVXjHfW&vxp=mtr
Nope. Mine are all converted to led. No problems.
I always had cheapo eBay leds before and never again. They would burn out or start to flicker. Pay a little more and get a quality bulb. I run the zevo 194 in my plate lights and philips leds that were 35 for all 4 for the cargo light and reverse.
Edited by cbrsilv15
My brother in law has the MX4 and it is a nice feature over my HD which you have to lift before you close the tailgate.
Where can I get these bulbs?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
