My truck is new(79 Miles on it) got it yesterday, today 0 degrees, would not start. Got out the hammer and wrapped on the exhaust and it started. There is some kind of exhaust flap i read about here that has been causing issues! On my way back to the dealer now! Not Happy
Did it crank when it wouldn't start?
Partial update here. They had the problem starting it this morning, they said the voltage was normal. They are waiting to hear from GM on the next course of action. Mentioned they might try a new starter. That's all for now.
SSimpson, is it cold where you are at?
OP stated in his initial post that it was zero degrees, I would say yes, it's cold.
Read OP, nothing about temp there.
Edited by chelmer
Uh...really "My truck is new(79 Miles on it) got it yesterday, today 0 degrees"
I think I identified what caused my truck to fail starting. I bought a Range V8 and installed it last week. I drove the truck once, and then it stayed parked for 5 days. Then the truck wouldn't start. I remembered the Range V8 and went to their web site to contact them and ask if the unit could cause a battery drain. I found this information on the site:
The Range Device does draw on the vehicle battery during normal operation. If you drive your vehicle daily (or almost daily), then this will not be a concern. However, if you drive your vehicle infrequently (i.e., only on weekends), please remove the device. It is best practice to remove the device if your vehicle will sit for anything longer than 3-4 days.
So I can testify that this is absolutely correct. :rollin:
We'll GMs answer for mine is to put a new starter in it. They are overnighting one from Canada and will let everyone know if it solves anything.
I test drove a 2014 Silverado, took it home overnight, went out the next morning, it would not start, it just clicked would not turn over. Temp was 0F, went out five minutes later, turned the key, turned over a few times then started. My buddy is the sales manager at this dealer and he told me if they keep the trucks in transport mode, they all start no matter what the temp, but if they take them out of transport mode, half of his Silverado's will not start. From my understanding, transport mode turns off all unnecessary electronics on the truck. He also said that his dealer rep from Chevy says most of his dealers are complaining about the same thing. I am getting my new one next week, I hope it warms up and Chevy can come up with a fix for this.
    Fishboat
    Fishboat
  • Who's Online   7 Members, 0 Anonymous, 491 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
