New Tires for My Sierra AT
GMC-AT
I'm thinking about getting new tires. I want something a little higher and a little wider. I have a 2in level already in the front. What size should I get ? Keep in mind, I just want a little bigger than stock... and don't want to lift the rear end at all.
I currently have 275-55-20. should I get 275-65-20 ? but those wouldn't be an taller correct?
They'd be about 2 inches taller. Higher aspect ratio = taller. I don't know if they would fit as that's about a 34" tire.
275/60/20 is about an inch taller. Not sure about those but I'm pretty sure people run them with a level.
I have 275/60/20 on my AT and they still rub a little bit at full lock. I was surprised because several folks on here are running 275/60/20 with 2" level and claim no rub. Best I can tell they are rubbing against the control arm. Not a big deal to me but I would suspect that 275/65/20 is going to be worse. Mine are Cooper Zeon LTZs.
Ok.,. also I don't want any chances of rubbing. With that said.. the 285's would be too much? I should stick to 275/60/20 or 275/70/20
That's odd that yours rubs and mine doesn't. I have the same tires with just an Rc level. I checked after I put them on then later when I put some miles on them. I have about 2000 miles on them now. Mine is a 4x4 and not a z71 but I don't know if that matters..
Wouldn't think it would. I have the exact same setup. But then again maybe its a difference between the aluminum and steel control arms. Who knows. I have almost full range of motion, just that last tiny bit at full lock that rubs. I almost never need to turn that hard. I haven't been able to confirm exactly where it rubs because I can't maintain that much turn without physically holding the steering wheel in place. Letting up on it to go check turns the wheels back just enough to not rub if that makes sense.
Hey guys I have 2.5 rough country lift and I want to get aftermarket rims and tires what offset rims and tires can I get? I want an aggressive tires, any ideas or did what did you guys do? I don't want any rubbing
Not sure on a 2014 with a level kit as I put a four inch lift on mine and had to get rims with less backspacing but on my 2010 with a 2 1/4 level kit, i had 18 x 9 rims with +18mm offset and 275/65/r18 durotrac tires. I loved them and they both looked good and the tires are the best all terrain tires out of all that I have tried for actual mud and snow/ ice use. They just barely cleared the wheel wells but they did clear everything.
They would fit on a 2014 for sure with no rubbing anywhere. You might even be able to go a little bigger.post-125934-0-92957400-1391484170_thumb.jpg
I put the same size rims and tires on my 2014 but on rims with zero offset and there is about an inch of clearance everywhere. Once again that is with a four inch BDS lift
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
