Towing with the 6.2 V8
yeah from what I have read on here,the towing power between the5.3 with 3.73 gears and the 6.2 with 3.42 is pretty much a wash,pretty evenly matched .
Ya I have crew cab short box and in owners manual both with 5.3 and 6.2 with 3.73 gears shows 11,800 max tow
Sent from my iPhone 6
using Tapatalk
  • Replies 97
using Tapatalk
I think the manual might be messed up. The new 2015 order guide shows your configuration @ 10900/5.3 and 11700/6.2. The 2014 guide is 11200 and 11800 for NHT in your config.
Does the max tow rating really matter if it is 11200, 11500, or 11800?
If you are towing 11000 lbs what difference is it going to make?
They did get lowered for 2015 and u can't get a 6.2 with 3.73 gears also in 15
using Tapatalk
It doesn't matter to me. I don't even tow 10k
using Tapatalk
  • 1 year later...
It would interesting to see how the 5.3L with he 3.73 rartio does compared to the others and the 6.2l.
I have a 14 1500 double cab max trailer pkg, 5.3l 4x4, 3.73s. From my understanding, this set up is the highest rated 1/2 ton for towing for 2014, with max tow capacity being 11,800lbs. I towed a 6800lbs 29' TT, tandem axle and weight distribution hitch, from Minneapolis, MN to Corpus Christi, TX. The trip was 1300 miles one way. Truck drives in 5th gear while in tow haul. I averaged anywhere from 6.2mpg a tank to 8mpg a tank at 65mph. Lots of hills, and wind played a large factor in the lower Mpgs. My previous 3700lbs trailer was towed from MN to Pascagoula MS, in similar conditions, and I averaged 8-10mpg.
I travel for work, pulling my trailer. After upgrading from a 3700lbs trailer to the 5800lbs dry trailer, I will be moving to a 3/4 ton. I'd like to stick with a 1/2 ton, but from the sounds of things the 6.2l does not perform much better.
A diesel will get a little better MPG towing but not that much based on what I see from posts here and my experience with a 2004 Duramax crew cab towing a 4500lb boat and trailer set up. I could get 12 to 13 with it towing the boat at 65 to 70 mph typically. I'll check what I get with this towing the same, sounds like I should expect around 10mpg. The mpg really drops off fast with a diesel with speed because it takes the engine out of it's sweet spot for RPM which is where they really shine. Towing at 55-60mph I got about 15 with the Duramax and that boat.
    • Oh yes, someone is going to be certainly hitting up GM service/ support for a 20 year old truck.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
