Towing with the 6.2 V8
Looking for advice if this trailer is ok or too heavy for my new 6.2L, max tow package with 6.5 ft bed, 4x4.
Fifth wheel dry weight of 7850lbs
Dry hitch weight 1428 lbs
GVWR 9350 lbs
  • Replies 97
Probably so. You have the same setup as me. If you consider you, family, dog, you are probably at 5800 to 5900 lbs. Add 100 lbs for a 5th wheel hitch, that only leave you 1200-1300 lbs for hitch weight. Then you have to calculate your hitch weight loaded. If you add 1000 lbs, and load it to maintain about 15% of total weight on your hitch, that puts your hitch weight at 1600#.... you are exceeding you 7200# vehicle gross weight by at least 300#. I figured I need a 5th wheel with a dry hitch weight of not more than about 1100#. They are out there but not very large and are hard to find. On the other hand, TT can be found easily with 600 to 700# hitch weight. Max hitch weight for a bumper pull I believe is around 1100# with a WD hitch.
Just realized you have a 4x4. That will reduce you payload since 4x4 is heavier than 2wd which is what I have.
The way I have it figured is my truck is rated for 9600 lbs for a loaded fifth wheel. 20% of that give me a loaded hitch weight of 1900lbs. 15% is 1440lbs. So I think that I am right in their. Maybe add a set of air bags for ride quality, but should be good.
[PDF]2014 chevrolet trAIlerING GUIDe
www.chevrolet.com/.../Chevrolet/.../MY14%20Trailering%20Guide_1113....
10 SILVErADo fIfTH-WHEEL/GooSENECK TrAILEr WEIGHT rATINGS ... Silverado 1500 ... fIfTH-WHeel HITcH anD GoosenecK HITcH These are designed.
I'll be picking up my crew cab 6.2L with max tow package Monday or Tuesday, and after I get a few miles on it and tow a little bit, I'll give you my impression. I will be towing a race car trailer at about 7,000 lbs, or my travel trailer at about 5,000 lbs. Not sure which will be first. It all depends on how soon I get my truck broken in and the race schedule at that time. I'm going either racing or camping soon!
I am purchasing my Denali 6.2L for towing my 20' enclosed trailer and Corvette....trailer is #3500 empty and the Corvette is right around #3400. I have used my TrailBlazer SS to pull which it does as long as I'm not going up and down hills. I borrowed a friends 2013 2500HD with the 6.0L gas motor with 3.73's and it pulled it fine up and down hills. This is the reason I went with a 1500 truck over a 2500HD plus the 2500HD rode like crap when it was empty. I can get the nice ride from a 1500 and tow power from a gas motor of the 1500. I only really pull the trailer no more than 4-5X a year so a diesel was out of the question. When I get my truck I will have the rear airbags installed to assist with the weight, cold air kit, exhaust, tune and if the truck doesn't feel right with 3.42's, I will most likely change to 3.73's.
Well, it looks like I'm going racing before I go camping. I'll be towing my race car to the track this weekend. I'll be back on Sunday night and I'll let you guys know my impressions next week.
Bill
Ok, had a short towing trip, about 70 miles, 95% highway... I have the 6.2 with max tow, 4x4 crew standard bed. I towed a camper with a weight of approx 8500-9000 lbs. Average MPG while towing was 9.2... That was with the tow button on, and in 5th gear most of the time... Cruise set at 66mph... I was hoping for 10-11 but still better that the 6.5mpg I used to get with my 2012 Yukon Denali... In flat terrain also...
Good to know....thanks for the post.
i have 2014 Denali with the 6.2L motor and 3:42 rear end. I have pulled my 16' tandem axle utility trailer load down with atv's and coolers if you know what i saying. I pulled the trailer about 2000 miles round trip. the truck has tons of power. No problem draging it down the road. The only problem is the MPG. I averaged 8 mpg driving 75 to 80 mph. Even 8 mpg doesn't not kill me, the 26 gallon fuel tank does. I wish GM offered a 36 gallon tank like ford. Atleast you would not have to stop every 200 miles for fuel.
I don't know if the 3:73 rear on the tow max will make a differance. Maybe it will.
Changing to 3.73's would help on acceleration and going up hills etc keeping the RPM's in the peak range without having the trans to downshift. I am sure MPG's would suffer just a small bit but that should save more wear and tear on motor/trans in the long run. Just waiting on a manufacturer to come out with gears for these trucks and I will be one of the guys in line to buy them.
Here is a review on the 2014 Silverado 6.2 on towing.
Yeah, I wish they would have kept it in manual mode when going up the hill. They could have easily kept it above 60 MPH the whole way.
Anyway, the best part of that test is probably going down--10,000 lb trailer, one of the steepest passes in the country, and they didn't need to even touch the brake pedal. The brakes were basically cold at the bottom of the hill. That's impressive.
I agree with the brakes but do you feel and eight plus speed transmission would do better on this test under the same circumstances? They also mention they felt Chevy geared the transmission to get better gas mileage.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
