helped a friend put one on his 07 chevy, your right the holes where about half an inch out. we ended up notching out the corners of his box to get the clearence we needed, you dont even know with the bumper installed
Looks like I got myself a mini weekend project then. Appreciate the feedback
  • 7 months later...
Hello all. So i got a bumper from a '14 to put on my '11 silverado. Problem is the bumper brackets are different. It looks like I could just do some minor fab work to make it fit. Anyone had any luck doing something like this? thanks in advance.
Nice job shortnulgy! That's one hell of a detailed writeup! :thumbsup
Edited by 2009 GMC
  • 7 months later...
Hi
I was wondering if the photos are available anywhere.
I saw them all a while back but now that i'm finally getting around to installing the bumper, no more pictures.
Thanks
I am actually wanting to take my 2014 1500 reg cab bumper off and get one without the steps from an older one.......assuming this is possible too?
Cant see these pics.... maybe I don't have enough posts yet? Privileges?
It's an issue with where the pictures were originally hosted and then linked to
okay thanks man!
Can you send me the pictures?
i am interested in putting the same on my 2012 GMC Sierra Z71
7 hours ago, CodyKruger said:
Why can i not see any of the pictures
It's an issue with where the pics were hosted and linked to...if it was photobucket, they are now charging to host pictures and won't allow pictures already being hosted to be seen.  If they were hosted on this site, the site has gone through an upgrade recently and the pics probably didn't survive the upgrade.
  • 6 months later...
Anyone know if the gmt900 trailer wiring harness plugs directly into the dual plug adapter that mounts to the gmt1000 bumper?
Also, does the gmt900 spare tire tube lock cover swap over to the gmt1000 bumper?
My 2014+ bumper came with neither parts.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,140 Guests (See full list)
