Engine bogging down at lower RPMs
juf
Does anyone else's engine seem to bog down at lower RPMs? Many times when accelerating it's as if the engine is choking on itself then catches up once a higher RPM is reached.
Another funny thing is when driving slowly up a steep incline. The truck seems to stay in 2nd or 3rd gear until it almost stalls. I'll press the pedal in a good one to two inches before it downshifts to first gear at 4k RPM. Seems like a 5.3l should have enough power to drive up a hill without downshifting to first to avoid stalling.
Possible fuel pressure problem?
what gears does your truck have? if its the 3.08's its gonna take a bit of push on that skinny pedal to get her moving.
Ha that's what it seems like! My 08 Sierra had an easier time accelerating and going up steep hills.
Does anyone else's engine seem to bog down at lower RPMs? Many times when accelerating it's as if the engine is choking on itself then catches up once a higher RPM is reached. Another funny thing is when driving slowly up a steep incline. The truck seems to stay in 2nd or 3rd gear until it almost stalls. I'll press the pedal in a good one to two inches before it downshifts to first gear at 4k RPM. Seems like a 5.3l should have enough power to drive up a hill without downshifting to first to avoid stalling. Possible fuel pressure problem?
I have the same issue and was wanting to know as well with the bogging down/hesitation at lower rpm's. I also have the 3.42 gears. Can't comment on going up a hill, it is all flat land here. I think I remember having this on my 2005 GTO, wonder if it has to do with the throttle being electric instead of a cable?? Would a tune take care of this problem?
my 5.3 and the 3.42 gears gets up hills no problem. You just gotta get into the skinny pedal a bit more compared to your 08 with a 4 speed trans. The 6 speed trans needs more throttle to downshift. Don't be afraid to rev the engine up...that's what they are made for.
I HAVE to push the pedal down to get it up the hill. Just seems a little ridiculous to downshift to first gear at 4k RPM to make it up when an older vehicle cruised up no problem.
Under light acceleration, the truck will remain in V4 mode and almost feel like its bogging. Mine does it as well and i just push the gas a little more and you can watch it go into V8 and feel it light up right away. Just put a little lead in your foot lol.
Disclaimer: my 08 was blackbear tuned. Might have spoiled me a little. Too paranoid to tune the new truck because of warranty though.
  • 1 month later...
Combo of Variable Valve Timing, V4, 6 speed. Mine does the same thing. Sometimes at low speed , stomp the gas pedal and NOTHING. Like a deer in the headlights for a second or two.
This is why I like manual transmissions. I currently have one in the 2013 Chevy Sonic. Although I have no complaints about the 4 speed auto transmission behavior either in my Silverado or Impala LTZ. Impala especially is very quick to downshift when you push on the gas pedal even slightly. Silverado requires slightly heavier throttle to downshift but then the non-AFM 5.3 has a lot more torque than the 3.9 liter V6 in my Impala so it can run at lower RPMs in the fourth gear without feeling too strained.
I believe that GM in their effort to maximize the fuel economy has pushed things too far on these new trucks and maybe some aftermarket tuning can fix it? We have a 2012 Silverado crew cab 4X4 with the 5.3 AFM engine/6 speed auto at work and I do not find any issues with the transmission shifting. I cannot tell when it is switching between 4 and 8 cylinders either.
Do you still have this problem?
Did you take it in?
Did you figure out a way to encourage to downshift but not all the way to first (or whatever gear is resulting in 4000).
Yeah, still have the problem. Took it in to dealership twice, but they aren't any help. They just say there's no codes, and won't look into it further. Seems almost like a fuel pressure problem or spark problem, but I don't have the means or know how to check it out myself.
I did get a diablosport tuner, and the canned tune seems to help. Just started the process for a custom tune from Lew.
I did do a log file and noticed the fuel pressure drops when first accelerating. Does anyone know if this is normal?
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
