Time Changes Automatically?
Xm or onstar or nav antenna
Sent from my SM-N900V using Tapatalk
Cell phones change automatically too
Ryan
In my truck there is a clock setting of manual or cell network. If set on cell network it changed on its own. Mine did!! ?
This is correct. I just did this setup the past weekend.
Mine changed as well. That was a nice little surprise Sunday.
so if that setting for "change on cell network" is enabled, it will change the clocks even if the truck doesnt have the wifi hotspot option?
Kinda cool. I turned it on in my truck but it was already past the clock change
I had to check it out this morning after reading these posts last night. It did it all on its own...nice!
Sent from my iPad using Tapatalk HD
I didn't even know the time changed until I looked at the only two "old" clocks in my house, all of my other ones change on their own.
I had to change mine manually today. My Onstar and xm are both expired.
COuld be wrong but...I don't think it has anything to do with Onstar or XM. The time is picked up from your cell phone and it's a setting that you can turn on in your infotainment menu.
  • 5 years later...
I drove 2 counties west and did not cross time zone but my clock changed back 1 hour going out and back to normal time coming home.  We live in central Kansas.
Any ideas???  Has me baffled.
Mine will not sync the time with my phone, a bit of a pain in the arse as the clock gradually gains time so I have to set the clock every couple of months back a couple of minutes.
I have the setting for syncing time with the phone but it has never worked, I have two different phones, time doesn't update with either of them, same goes for the time zone change, never has worked.
2014 WT
Sent using Tapatalk - 2014 5.3 WT
    mark2
    mark2
  • Who's Online   4 Members, 0 Anonymous, 593 Guests (See full list)
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
