Blank Touch Screen after start-up
My truck has done this intermittently from day one. I have had it in 3 timed and the dealer could never duplicate. I will take it in today with this info I found. Hopefully they will fix it!
Blank Touch Screen after Start-up and in Reverse
The infotainment touch screen may be blank after start-up and in Reverse, a rear- view camera message may be displayed, and there may be Bluetooth® and naviga- tion system conditions on the following models equipped with radio-infotainment system RPOs IO4, IO5, IO6 or RAO (except with RPO UPF):
2014 LaCrosse built prior to September 24, 2013
2014 Regal built prior to August 26, 2013
2013-2014 ATS built prior to September 23, 2013
2013-2014 SRX built prior to September 12, 2013
2013-2014 XTS built prior to August 21, 2013
2014 CTS Sedan (VIN A) built prior to September 23, 2013
2014 Corvette built prior to August 5, 2013
2014 Impala (VIN 1)
2014 Silverado 1500 built prior to October 1, 2013
2014 Sierra 1500 built prior to October 1, 2013
Some possible Bluetooth conditions include the screen not returning to the Home screen after ending a call, cannot call contact work/mobile number for more than one contact with the same name, and issues concerning speech recognition .
Some navigation conditions include no results found after performing an address search with an incomplete address, the selection of a Point of Interest address delivers a wrong destination position, and the map freezing when panning in the 10k zoom scale .
An updated software calibration has been released to address these conditions .
Update the Human Machine Interface (HMI) module using a USB flash drive and the Service Programming System with the files available on TIS2Web .
TIP: The USB flash drive programming event requires a USB 2 .0 flash drive with
a minimum capacity requirement of 4 GB . The software downloaded to the USB flash drive can be used to update all applicable vehicles .
After USB programming has been com- pleted, reprogram the HMI module using the Service Programming System with the latest calibrations available on TIS2Web and then clear any DTCs .
TIP: The vehicle modules must go to sleep for five minutes after programming the HMI module . If not, the vehicle may have a blank screen, no sound, no touch response, or the wrong splash screen may appear on the screen . If this happens, turn off the vehicle and wait the required five minutes before starting the vehicle again .
For RPO IO5, there was a production change in the software that changes the Navigation icon display to the Navigation OnStar icon
Had mine updated to fix this Bluetooth condition listed below which is annoying, but haven't had a chance to test it yet...I did not have the blank screen issue.
"Some possible Bluetooth conditions include the screen not returning to the Home screen after ending a call, cannot call contact work/mobile number for more than one contact with the same name, and issues concerning speech recognition ."
Where did you find this info? I'd like to print it directly from the site and take to dealer rather than off a forum. Thanks, great find.
Hi EelctraEd,
I’m sorry to hear of this concern with your truck. I’m glad to see that you found some information to take to your dealership that may help with your problem. Please feel free to follow up with us via private message regarding your dealership visit. I will be glad to document your concern and feedback within our system. If you have any other questions or concerns pertaining your truck don’t hesitate to let me know. I look forward to hear from you!
Kristen A.
Chevrolet Customer Care
I have a appointment tomorrow at 8:30. I'll let you know what they say.
Any update from your trip to the dealer?
I have this same issue intermittently. If there's an update that will fix it I'll take that techlink article to my dealer the next time it happens and get them to look into it. I've found that if I shut the truck off for 5 minutes and then turn it back on the screen will work again.
Exactley, that's what I have to do as well. It's an inconvience.
Mine did this and has worked great after the update.
Yep, sorry been busy. New flash seems to have fixed it. Although I could never predict when it was going to happen before, but its has completely stopped so far.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
    • My point was: If what you are doing works, keep doing it:   But, I will have a talk with AI to make sure their info is more accurate going forward.
    • Hello There I have a brand-new engine control module (ECM/PCM) for the Duramax 6.6 liter diesel engine. GM E41 ECM on 2017–2023 6.6L Duramax L5P trucks Bought it for a project last year and end selling the truck, so i never get to use this ECM LP5/E41 I paid $1499 willing to sell it for $1200 OBO
