Mobile (in vehicle) Wi-Fi Routers and Internet service
Anyone familiar with and using an on board mobile (in vehicle) WiFi router via cellular service provider subscription such as the Autonet KT-ANMRTR-4 or similar device. I am interested in installing one to have and maintain online internet access and connectivity for both my business and personal needs to include streaming real time audio source files, e.g. Pandora or other commercial free internet radio.
I am aware that I can stream from my mobile devices (roaming) but understand that installing a WiFi router designed for vehicle connectivity is much more reliable.
Note: I am located in Alaska where Sirius/XM satellite service is not available but we do have reliable 3G/4G cellular/wireless service available from the likes of AT&T and other carriers.
I'm not a "tech guy" and would appreciate any advice or sharing of personal experience (i.e. Pros/Cons).
Here is another option that plugs into the truck systems, but I don't know anyone that has it...this one is at GMPartsDirect.com. It shows a picture of a Buick, but it lists 2014 Silverado and Sierra
http://www.gmpartsdirect.com/results.cfm?singlepart=1&AddPartNumber=22871071&partnumber=22871071
22871071 - MODULE KI 22871071.jpg GM PART #22871071
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
List Price: $535.00 Price: $393.23 You Save: $141.77 (26%)
If the normal cell providers don't have service how do you expect this to work? It likely piggybacks off one of the big cell companies, like OnStar does with Verizon.
Mike, The OP said, "Note: I am located in Alaska where Sirius/XM satellite service is not available but we do have reliable 3G/4G cellular/wireless service available from the likes of AT&T and other carriers." So I assume this device uses one of the 3G/4G services he mentioned?
Id go with the gm one if it will work up there for the same cost because id assume its plug and play
My dealer said, it will cost you $19 per month for 1 GB.. The WFI Unit is Extra. ;)
My bad, I read it as cell service was unavailable.
No problem...
That's what I was thinging
We have good cell service up here I have AT&T and have 4G LTE but as he said Sirius/xm is almost non existent up here.
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
