Free Oil Change Issue?
I was told by 2 different dealers that if I change my own oil and even if I keep the sales slip and you have a problem with your engine GM will NOT cover you. How do they know you put this oil and filter in this truck ? Because you go to the dealer to have it done it is documented.
I let each of them do 1 each and after I got ripped off (see my other post in this forum) I just did the 3rd myself. I'm tired of this he said she said BS from every one in it for a buck. I'm in it for myself from now on. If I have any problems down the road I make a phone call and let the attorney deal with it and I have everything documented so far including 3 oil samples from all 3 oil changes.
  • Replies 68
K I was just reading up on this and see ppl said like you that the dealerships said they have to do it and others saying just keep receipts and records. They can tell if oil is crappy when they drain it meaning if its way old or whatnot. I don't believe they can void the warranty. Give you a hard time.. Maybe but void. ... I agree lawyer time I did mine and in the book wrote down date, mileage, olm, and a receipt for the oil used
Sent from my Nexus 6P using Tapatalk
You would think they would want to cash out your oil changes as fast as possible so you start paying the dealer for them. Perhaps they want your engine to self destruct after your warranty expires. They told me i can leave it for 12-15 000 kms. I told them not with the cheap semi syntheic you guys put in these things. One more change and its Mobil One from here out.
The owner's manual talks to the idea of the owner doing some of their own maintenance. They even mention that it's important to keep the records. Here is a copy & paste....
Vehicle Checks
Doing Your Own
Service Work
{Warning
It can be dangerous to work on
your vehicle if you do not have
the proper knowledge, service
manual, tools, or parts. Always
follow owner manual procedures
and consult the service manual
for your vehicle before doing any
service work.
If doing some of your own service
work, use the proper service
manual. It tells you much more
about how to service the vehicle
than this manual can. To order the
proper service manual, see Service
Publications Ordering Information
on page 13-11.
This vehicle has an airbag system.
Before attempting to do your own
service work, see Servicing the
Airbag-Equipped Vehicle on
page 3-34.
Keep a record with all parts receipts
and list the mileage and the date of
any service work performed. See
Maintenance Records on
page 11-16.
Let's not forget the fact that GM credits every dealer that does 1 free oil change the sum of $50.00. Any dealer that is charging any fee other than the difference in price of blend to full is making money off their customers for free oil changes.
Call it what you will but I say it is unfair business practices,running a racket and making money off GM. As one other member said you already paid for those free oil changes in the price of the truck.
I'd look for another dealer. Mine will change the oil up to twice a year for the first two years regardless of the DIC readout.
Never use them anyway because I want to run full synthetic not their Dexos blend, I know how much was put in, and the plug and filter properly in stalled and tightened. And as far as documenting your oil changes.....they'll accept writing them down in the back of the owners manual or use the OnStar Email printout. The bottom line is it really has nothing to do with documentation....whether or not you have regular oil changes will be apparent once they pull a valve cover and examine the deposits or lack thereof on the cover, rockers and spring assembly, and the PCV system.
Even if you use the dealer for oil regular changes and upon examination they find cooked deposits or scored bearings with adequate oil pressure, they'll find another excuse to deny a warranty claim, e.g. overheating/misuse of the engine, improper additives......
That is utter BS, and not legal. They cannot avoid liability under the warranty if you have your oil changed somewhere else or you do it yourself. That's a con they run because they want to sell you something else. Frequency of oil changes is the key to success in pushing related products and services for the OEM dealer. A few free oil changes can go a long way toward increasing the amount of money a customer will spend at the dealer during the ownership of the vehicle. In other words, you are money in the bank.
Per the FTC
Do I have to use the dealer for repairs and maintenance to keep my warranty in effect?
No. An independent mechanic, a retail chain shop, or even you yourself can do routine maintenance and repairs on your vehicle. In fact, the Magnuson-Moss Warranty Act, which is enforced by the FTC, makes it illegal for manufacturers or dealers to claim that your warranty is void or to deny coverage under your warranty simply because someone other than the dealer did the work. The manufacturer or dealer can, however, require consumers to use select repair facilities if the repair services are provided to consumers free of charge under the warranty.
Never had an issue. Take mine in at roughly 5K. I'm now 40K Miles and performed 9th oil change. Dealer never squawked ever.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 551 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
