As suggested in another thread, I figured I'd try to get this going. It'd be really cool if all the 2014+ forum members would post your wheel/tire set-up in a central location.
Post some pics, and include details on sizes, offset, backspace, lifts, levels etc.
Also tell us about any rubbing and/or trimming required to run your set-up.
Thanks
I guess I'll be first since it was my idea (LOL).
2.5“ Pro-Comp level, front only.
18" factory Z71 wheels, 18x8.5, +24 offset
Toyo Open Country AT (not AT2) LT275/70R18
No rubbing, no trimming.
Sent via Samsung Note II
  • Like 11
Here are mine:
2" RC level
20x9 OE wheels machined black. +31 offset
275/60/20 Falken Wild Peak AT
No Rubbing or trimming
  • Like 12
I'm in... Man I need some new pics if rain would stop messing up my truck ha
305/65 18x9.-12
IMG_20140418_135844876_HDR_zpsxiv2z3fm.j
IMG_20140418_135821902_HDR_zpsssfawpvs.j
Edited by Full Lock
  • Like 17
SEY CK156 22" GM wheels, 285-45-22 Bridgestone Dueler A/T, no lift, no level, no rub.
  • Like 11
Not mine, only seen this beast for like 4 min :( ,,, talked to the owner for 1 min. Said he had a 7" lift and 35" tires I saw that the rims where 22" ... When I pulled up to his truck at work. Hope he doesn't get mad at me posting his truck here... For the 3rd time ;)
That pic is my phone screensaver:)
  • Like 4
Lol are you a stalker? He might get a little creeped out
Lol, not at all it's just the first truck I saw like mine in person that had stuff done to it. I've only had mine for almost 3 weeks. I'm saving now for tires/rims for winter setup.
18 x 9 rims with zero offset. BDS 4 inch lift. 275 65 R18 durotrac tires.
No rubbing and lots of room actually. I think 33's wouldn't rub either.post-125934-0-63570700-1400279008_thumb.jpgpost-125934-0-54476500-1400279050_thumb.jpg
  • Like 7
305/60-18 (33x12.50-18) Cooper ST Maxx on OEM Chrome RT5 All Terrain wheels, no lift, no rubbing. Now leveled 1.5".
Edited by spurshot
  • Like 4
22" SEV CK162 6 spoke black, 285/45r22 Dueler H/L, 2.25 Level, No rub. Cheers :cheers:
2.25 Level
2.25 Level Kit
No rubbing and lots of room actually. I think 33's wouldn't rub either.attachicon.gifimage.jpgattachicon.gifimage.jpg
With your 4" I'd bet you might squeeze 35s. What wheels are those? Look kind alike fuel dunes but not.
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 463 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
