nice what do you want for the wheels
Just sent you a PM but looking for $1200 for rims,tires,tpms,lugs and locking lug kit.
Finally got my Methods!!
17x8.5 -0 offset NV machined
Toyo At2 285/70/17
Fox 2.0 all around
No rubbing and got more than an inch at the nearest points with zip tying the liners back.
The SLT wheels/tires are up for sale if anyone is interested!
46553c66fe157ef6dd57cde9d562e4f3.jpg8557f4ed97bbc6fb37f7755b74d299c1.jpgccee83bd22bf1f423389a1721bfe81f8.jpg
Dude that looks AWESOME!!!!! Great choice!!!
2" RC front level
XD Grenade 820 wheels 20x9 +0 offset
Falken wildpeak at3 tires 305/55/20
-just barely touches that bottom fender corner trim piece. Only makes a rubbing noise off that piece in reverse at full lock and it's very small
Love this. I'm looking to do a 20x9 +1 with the same tires. I may get bashed for this, but how did this affect your gas mileage? I drive a fair distance to work each day so this really is a factor for me.
probably get around 16 mpg after the switch.
More aggressive tread will lower your mileage. I could stretch my stock bridgestones to 19-20 on the highway now I see 17-18
On the highway? That's disappointing.
I usually get 22ish(60mph) mpg on my stock bridgestones headed to work. This fall our company is moving, so ill be going about 70 then and now at 70 i'll usually sit around 19-20, so losing 1-2 isn't too bad.
What tires did you move to? These falken's are almost 2" wider than my 265/70/17 i currently run.
Edited by pbudde18
My speeds with the 285/45r22 bridgestones were 75-80mph getting 19-20mpg
My 285/70r70 nitto ridge grapplers at 70mph are 17-18mpg. I haven't adjusted my speedo so my range computer is off. If you calculate the small tire diameter difference it puts me at 73mph and 17.3-18.3mpg.
Does anyone have any pics of the 22" sey wheels with Nitto Grapplers? I searched but wasn't able to find any photos.
Also is 245/45/22 the biggest you can go at stock height?
I have 285/65/18 nitto ridge grapplers and a two inch level. I'm getting around 16.5-17mpg's but that's daily driving so it's really not bad
At what speed? The Falken Wildpeak AT3/W are not quite as aggressive as the ridge grapplers so i'd think that'd help me.
I believe wild peaks are heavier. It's city driving so between 0-65 mph in Atlanta traffic
Yeah they are heavier. Looks to be about 13 lbs heavier and 1/2" wider or so. Most of my driving is more highway. I'd think to get around 18-19 or so doing 65-70 right?
id be expecting to lose atleast 2 mpg from what you're getting now
Edited by MicahLo
Sounds acceptable to me. I'm between 22-23 mpg on my way to work now cruised at 60 for about 33 miles. This fall i'll be going down to about 24 miles cruising at 70. Shouldn't see any real increase in overall fuel usage monthly. Works for me. Thanks for the help, very informative!
no problem. I'm just guessing from my experience though. I never get 22mpg in my truck even when it was stock lol. Traffic in Atlanta really sucks so that probably contributes to it
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
