Here's my setup. I kept the size 18 wheels so I could keep the stock tire. I paid $535 plus tax for the new wheels but with tax and installation plus new lug nuts (stock lugs are too wide) it came out to $730 out the door. Wheels are by Pro Comp model 5034 common name Rockwell. 18x9 6x5.5
Before
After
Hello,
New to the forum as I just signed up today but have been lurking since I got my truck in late 2015.
My wheel and tire set-up are as follows:
17x9 -12 offset Method Race The Standard in Matte Black
General Grabber X3 35x12.50R17 - Red Lettering
1 3/4" hub centric spacers are in installed on the rear axle
Truck is currently lifted 6.5", no rubbing
welcome
I think i've changed my mind on my plans. Ill probably go for a 20x9 +20 with 305/55's on a 2" level. How well would that work out? What can I expect in terms of rub and other issues?
Here is mine
2" RC Level
285/65r18 Trail Graps
Stock 18s
I plan on going to a 20X9 w/ a 295/55r20 here in the next few months. Have any of you successfully put on a 295/60r20 on 2" level w/ out trimming? I am looking at aroun +14 - + 18 offset wheels.
Yes20170407_123911_zpsrv2foveq.jpg20170407_123901_zpsix1r8jsw.jpg20170321_124010_zpsjhydild8.jpg
I had to ziptie the front fenderwells on the inner rear corners, that is all.
Edited by krzyd
You need to pay attention to what version your control arms are (cast steel vs stamped steel vs alum) and what offset/backspacing people are running. There are reports of people rubbing with 305/50r20s, but I think they are on stock wheels with stamped arms. Others have run that with the same thing with minimal to no rubbing. So I think the control arms are the differences.
Moving from a stock offset (assuming +27 on a stock 20" wheel) to a +20 offset will gain you a little bit, but you still may not clear the control arms completely if they are stamped or alum.
I'll have to check out which ones i've got. I have the 17" wheels so I think my offset is actually only +24 offset. So i'd gain nearly next to nothing. The other offset option for these wheels is +1, or -12. So the 305 tires would be about 1.6" wider than I have right now. So if I go with +1, i'd get .9" saving from there. So effectively my tires would reach in an additional .7" or so. Think that would work? I just don't want a silly amount of tire sticking out from the well. A small amount is fine.
Hey guys I need some help. I'm buying tires this weekend and haven't decided on the size. I haven't seen much on here on 17s hopefully someone can help me. It's between 305/70r17 and 33x12.50r17. I'm going with the ridge grapplers and will be on 0 offset wheels and 2.5 leveled truck. I love the width of the 12.50 and the height of the 305/70
Is anyone running these sizes?
Edited by JayTee_17
Be prepared to rub and do some major clearance mods
Looks great!
I think that's the first set of 20" Methods I've seen.
There's 20s somewhere in these 251 pages cause
49dd38f3e08e8ed8689f38f132732680_i-seent
Edited by 5RWill
  • Like 4
Even with the 33x12.50?
I run 20x9 with a 0 offset. 305/55/20 - only rub is at full lock once in awhile on the inner liner in reverse. 1 little zip tie each side fixed that. No cutting, trimming, hammering etc. oh and all I have is a RC 2" level (bottom spacer).
Edited by Criscone
So I am torn.....help me decide. I will be upgrading to either a 20X9 or a 20X10 in the next few months. I plan on running 295/55r20 Ridge Grapplers.
The 20X9 are 0 offset
The 20X10 are -19 Offset
I have a 2" Front Level Only
Will both of these work or is it safer to go with the 0 offset 20x9.
Also, help me decide on wheels. I want hostile sprockets but can't decide between black or chrome. I plan on eventually color matching the bumpers and grille if that makes a difference.
I have also considered Moto Metal 962s as well in either chrome or black.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 402 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
