Awesome review and answers IceMan. Thank you.
Too funny about the height difference before and after. VERY odd. [emoji848]
Still torn between Nitto TG, RG or WildPeaks. I’ll do some more price checking tomorrow.
Lastly, you chose the BDS level over others; such as the famous Rough Country. Why and what did it run you?
No problem at all! Glad to pass along info whenever I can.
To answer your last question; the short of I️t is peace of mind....
BDS offers a warranty that in my opinion isn’t beat or even matched by any other company in the industry. For the originally purchaser, BDS offers a lifetime warranty on their parts and a matched(supplemental) power train warranty for 5yrs/60,000 miles for the trucks factory parts. In other words if you break something on your truck and GM says I️t broke because the BDS kit was installed, even if you know they’re lying through their teeth; BDS will step in and cover the cost.
Coming from the modified Subaru scene I can tell you all about how the Magnuson Moss Act SHOULD work and how I️t typically DOES work...... so having an after company that will back factory parts is a huge value added for me.
The level kit was $138 in parts and with install and alignment it was $396. A little steep in my opinion for a level kit but part of the way they get you is the warranty is only good with authorized professional install. Would have loved to have done the install myself and saved the coin but such is life...
The break down was:
$138 parts
$155 install
$70 alignment
$33 NYS sales tax
I'm thinking about moving down rim size, and the tire place I go to is having a sale on rims and tires this rim being one of them.
On 10/17/2017 at 9:25 PM, RottenDiesel said:
Truck: 2018 1500 Denali
Level: Suspension Maxx set to 2” (front only)
Wheels: 17 x 9 XDs (+18)
Tires: Nitto Terra Grappler G2 285/70/17
Great looking truck. Does this set-up rub or require any trimming of the wheel well liner? I plan to drop down to 17 inch method wheels and wrap them with 285/70 Ridge Grapplers. And I’m leaning toward a 1.5 inch ready-lift front level. How much room do you have with the 2 inch level?
They look nice. [emoji106]
Sent from my LG-H872 using Tapatalk
They don't look awful I personally like my fuels better but I could live with themb6539634f25013daeb678197e56eacba.jpg
This is the rims and tires I'd be getting for a cheap priceadbcd2ef01e47b65c9d4ced09ca3fb31.jpg
I mean the rims look straight. I have the same tires on my truck except 305/55/20. Had them for probably 800 miles now. They seem good to me. I ordered mine through custom offsets
Lots of guys at work have them, I just want them to make my insurance go down a little with the snow rating. So for those tires and rims it's $1350 no tpms best deal I could find.
2" level gave me plenty of room. No rubbing at any point, forward or reverse.
Sent from my Pixel 2 XL using Tapatalk
Thanks for the reply. Hopefully I can stay clear with the 1.5 inch level.
Just purchased this truck. Currently on 265/65/18 Goodyear Wrangler Duratrac. I was thinking also of downsizing to 17, to look a bit more aggressive with 285/70 with maybe BFG TA KO2. leveling 1.5 or 2. Definitely don't want any rubbing or trimming. What you guys think?
Edited by Mazinger-Z
Did you mean  285/65r18 as those look bigger than 265/65?   And Duratracs are much more aggressive than KO2s.
285/65r18 and 285/70r17 aren't big enough size difference to be worth buying new 17" rims...both are going to fit fine with a 1.5 or 2" level.
Just got rid of some chrome. But it sits on a 2.5 lvling kit with 275/70/18 nitto grappler g2s. 21c2f9f0262659ba9545133ab5c3f36a.jpg
Method 20x9 with 0 offset
Kumho RoadVenture AT51 275/55R20
Factory ride height
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
