Damn... I should have gotten NV's instead of Mesh.
Sorry about your accident.
Thought i wanted Mesh for a long time until i started going back and forth between machined face and black. I love the black Mesh. I hate the machined face mesh. Dunno why. Ended up taking a liking to the NV and have been set on them ever since.
lol, I was upset. But once I pulled over the guy pulled in behind me and looked at his mirror and said, "I'm ok if your ok with it!"
:nonod:
I looked over to my fender and door and was like, "sorry man. I'm not ok with it. My fender and door are pretty dinged up"
Dude could barely get out of his car, I felt bad and wasn't all that upset then. Shit happens, hopefully his insurance forks up and pays for it quickly.
Just make sure and check out both 17" and 18" version of the NV's. The 17's have a more natural concave face where the spokes actually curve in. The 18"s are flat face and just have a lip around the wheel. They both look great, just depends on what look and tires you want to go with.
Will do i think i'll be fine with the 17s. Hell if 16s would fit i would get those. Cheaper tires is my game :D Plus the 16s my dad has on his 2500hd have really really grown on me. Love all that tire around a small rim.
Edited by 5RWill
^Dammit. They're now putting the wheels I just bought on the 2017 GMC's from the factory (Yeah I know the Silverado blackout has them too). At least I didn't buy rock stars or fuel mavericks or... :lol:
Forgot to post here too!
Sent from Tapatalk App - Samsung S6
Edited by Rawyzf
Should have taken my tono off before going tk get my goodies today... It all just fit haha c7cb89bf174e2760bae045c1b0bcf24e.jpgef91ee93fa8566478126b83a71e7092a.jpg
Sent from my SM-G900W8 using Tapatalk
Okay so gm wanted 700 to adjust my tune for my tires but they have a cheaper option by hypertech they recommend for me at 300 and it will fix my speedo and my tire size I don't jo much about it anyone know more. On this tuner or using it maybe?
Spend that money and buy a Diablo intune tuner. Much more beneficial. You can adjust tore size and also get much better performance over stock.
The Diablo was more money then the hyper and unfortunately I'm not risking voiding my Warrenty at least this way with the tunner I won't void warrenty asked gm already and it will fix my speedo and I can adjust up to 36" tires
Any guys run or know anyone that runs 20x12's on 33's with a 2.5" level? I have some 20x12's that I want to run on my truck with 305/55r20 Terra grapps but I want to get an idea of how much I'll have to trim.
Might need the 3.5 inch lift for that but I could be totally wrong
I ran into a guy on instagram that did it but it was a long time ago. I forgot his IG name. I have a picture of his setup.
I'm sure a 305/50 would work but I want to go 33" if it's possible without hitting metal.
Idk is tough, I'm sure it will rub. I have a 3" level and 20x10 -24 offset on 305-55-20 and it rubbed a little at full lock on the back carpet so I had to cut it and zip tie it back then hammer in some of the metal cus I wanted to make sure it would never touch it and explode my tire.
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Edited by NitroDatsik
So finally got the rims and tires on! I think it looks really good! Unfortunately my wife doesn't seem to like them... :( so may not get to keep them
Tires are 275/60/20 cooper Zeon LTZs offset of rims is +18mm
9029d442328aae67a3a65423fd7c2318.jpg526eeddcec0f69cd435b3a3a0d44dfc9.jpg97d06ec4cf2011205133304a540ea5e6.jpgc6056734095eb0db5d50ed8ec505a016.jpg
DROPKICK Edition
Test fit them. They rubbed really bad against the rear fender mold/lining. Any pics you can send me of the trimming and work u did?
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
