So finally got the rims and tires on! I think it looks really good! Unfortunately my wife doesn't seem to like them... :( so may not get to keep them
Tires are 275/60/20 cooper Zeon LTZs offset of rims is +18mm
9029d442328aae67a3a65423fd7c2318.jpg526eeddcec0f69cd435b3a3a0d44dfc9.jpg97d06ec4cf2011205133304a540ea5e6.jpgc6056734095eb0db5d50ed8ec505a016.jpg
Your wife tells you what wheels you can have on your truck? Come on mannn.
Just got my wheels on my truck tonight it got dark so pictures are kind of bad but. I'll get more tomorrow looks mean as hell imo over the stock wheels dd7323d15faba9ce527ea8505e998e1c.jpg4b377a1777bf1e91c6a3499b2a61c8f3.jpge46070e5c491f11ec754bdcbc3c77abf.jpg86e2db65faa62e06e3e8672fc2bdbea6.jpg5c20d0ed4c28fb7107b4c51b043ba2fd.jpg
So iv got pro comp 34 series wheels
18x9 with a 0 offset
2.5 inch level from the dealer with the little block in the back to level it completely idk the rear size.
Tires are bfg ko2 285/65/18 minor rubbing full lock in reverse because of my mud flaps.. Other then that perfect fitment with tiny poke
Will get better pictures tomorrow
Sent from my SM-G900W8 using Tapatalk
If you're looking for your man card, I found it in your wife's purse! :crackup:
On a side note, I think your wheel setup looks good on the iridium metallic!!
Edited by BowHunter1
I'm interested in seeing some daylight pics of this setup. How does that extra weight effect performance?
Seemed to do pretty alright on the hwy home yesterday didn't feel to heavy she is going in for its tune today to adjust tire size and speedo calibration so can't complain but I'll be for sure getting more pictures today
Here are some pics I just took.
Method NV 17x8.5 +0 Offset
Cooper ATP (E) 285 70 17
Sent from Tapatalk App - Samsung S6
b02e352cbd59ad67df1e8fe7a5117f99.jpg79486086d7756ceaa5917e63be6e831d.jpgcec26196e878940283769d9159ac1bb2.jpg32805a1f076d23f5fe7e4d0f032a0bf8.jpg
2014 Denali - 2.25“ level in the front, 2.5" block in the back. Fuel Maverick 20x9, +1 offset. 295-55-20 Cooper STT Pro. My driveway slopes slightly downhill. Slight rub in reverse at full lock. Fender measures 39.25" front, 40.5" rear.
Love it. Pictures don't do it justice!
Sent from my SAMSUNG-SM-N920A using Tapatalk
  • Like 3
:lol::lol::lol::lol::lol::lol:
Oh man, When I looked at the first picture I was like, dam, look at Rawyzf taking his truck off road and getting it dirty..... Then I scrolled down and saw you had just driven to an undeveloped part in your neighborhood.
[emoji38] [emoji38] [emoji38] [emoji38] [emoji38] [emoji38]
Exactly, that is funny!
Looks great! Your new tires are going to eat all the rocks off your driveway!
Oh, and you need to clean that blue off the sidewall so we can see those pretty white letters.
Yea I'll have to hit it with a pressure washer at the car wash! I'll be sure to snag more pictures soon haha I love the look my favorite is that little bit of poke ac1fd7dc0b14f584a119108f3fce95f3.jpg
18x9, +0, is that right?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
