CK106 wheels with black center caps and McGard black lugs. Michelin LTX A/T2 275/55/20. 1.0" front lift kit blocks.
There is no part number for the center caps in black that I can find, but I bought mine here:
http://www.ebay.com/itm/151763016007
I also put a coat of Cquartz UK on the wheels to protect them.
  • Like 4
cdd96e9e6e428bfaa4d15e1b1499924a.jpgb0a0f85788e3ea2dc907fba4d10fc021.jpgdeae8dac135e422a8b4b8471452dc8a9.jpg
35x12.5x20 Cooper STT Tires
20x12 -44 offset Fuel Krank PVD Wheels
8" Mcgaughys Lift
Any rubbing issues since the McGaughy's spindle lift kicks out the front wheels another 1.5"?? I'm currently at 8" 22x12 35x12.50 and no issues but might be going to a new spindle setup and curious if it is going to rub...
I had to trim the air dam a tad because of rubbing. I've seen others with no issues, but my setup having -44 offset wheels, makes it have some rubbing.
My latest:
5" RCX Crossmember Kit
1.5" Leveling Kit + Zone Rear Add-A-Leaf
1.5" Zone Body Lift
Total 8" of Lift
22x12 ET -44 Hostile Switchblades
35x12.50R22 Atturo Trail Blade MT
No Rubbing / No Trimming
I've been looking at a set of the Switch blades with some Atturo MTs also. What do you think of Atturos? Are they loud? And how is the tread wear? Thanks.
Are you guys with aftermarket wheels having to use hub-centric rings? I have a set of lrg wheels I am waiting to buy tires for and this just crossed my mind. I know fuel wheels come with the rings, but not sure if I will need them. I am going to call LRG eventually but just trying to get a quick answer from y'all. Thanks!
Beautiful. What headlights and Fog lights do you have?
OEM LTZ headlights (takeoffs) that I retrofitted with FX-R 3.0 3" projectors. I simply removed the amber reflectors when I had them apart. Fog lights are Rigid D2 SAE fog lights. If you want more info shoot me a PM-I don't want to clutter up the wheel thread.
My '15 Sierra 2wd with Z71 suspension package and 22" CK159's and Cooper Discoverer SRX 285/45/22.
Edited by mafd2
Best looking truck I've seen on here....
Got my Wheels and tires put on finally!
I haven't seen anyone with them yet and the week I get them put on, Ryan698 has them too...! Haha I didn't know how I felt about them at first but they really grew on me!!
Pro Comp Series 34 Rockwells
18x9 +0 Offset
Toyo Open Country M/T
35x12.50-18
So far I really like the setup! da069eb89e3d7fc7d04888197643156e.jpgf1041e6d9aa46b7cf570573a344cdcf3.jpg
I am planing on purchasing Fuel Maverick 20x9 for my summit white 2015 Silverado LTZ. The Silverado has 2" leveling kit and rear air bag lift. I'm trying to figure out the right offset. Anyone know what is the right offset is to make these wheels fit properly? I want to keep it as close to stock so they don't stick out past my wheel wells.
Thanks!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
