Looks great. I really like the white lettering out here, it looks good on the tall sidewalks and really gives some nice contrast to the color matching on the rest of the truck [emoji1360]
Ya, I wasn't sure which way to go, glad I put the white letters out! ??
Looks awesome Blue. I thought you were getting Nemesis? Or was that someone else...
Ya, I had my heart set on the nemesis until the local tire shop showed me pictures of the machetes with the same set up that they had done. Couldn't find many pictures of the nemesis being that they were new.
Finally got my new wheels and tires. 2016 chevy 1500 with 2" level kit & 285/70/18's with xd machetes -12 offse
where did you find BFG all Terrains In the 285/70/18 size????????
Upgraded to a 17' Silverado. Time to add some goodies. 2b2b02b825ea74230fec2dd7acbc5009.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
That's the combo my wife likes the best. Looks real good on Red, not sure about on my white truck.
Shane
Interested in trading for chrome handles and caps?
Negative. Might be selling the wheels though.
I love your set up. Too much offset for me but damn it looks good.
thanks!! [emoji1417]
Just installed Falken Wildpeak AT3W - decided on stock 275/55/20 size. As others have said about these tires the pics don't do them justice. Very impressed so far. These seem noticeably wider and the raised black letters look cool. Reasonable price and seem well made
0a241fa99abb62369f43c67d7ecb036f.jpg5d114f62b85ccf54a240f6929fdb2052.jpg9e96b006ec621f8591ced105cee90ef6.jpg
  • Like 4
My wife has these on her Tahoe. I like them and they were pretty dark cheap for 20s. She running 275/60/20.
Ive been looking to see what 33s look like on 22" wheels. I just might do it and keep the stock wheels.
yeah after negotiating I got these for $158 per tire which is remarkable considering they are even XL load capacity
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 471 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
