Post up your Man-Caves!
Luster
Cool I am a manufacturing engineer
Where at? Thats awesome. As you know ME's and IE's are almost the same, or at least around here they are. I'm hopefully transferring within my company next Monday to a ME position. (I hired on as ME but they put me at IE, I havent been REAL excited about IE lol.)
Yeah, I'm really lucky, all 4 of my sons and their wives live within 15 minutes of my house, not to mention my 5 grandkids! It's awesome to get to see all of them every week..... I really can't think of anything better. :thumbs:
Here's part of the group from last season....
Thats awesome! Very blessed to be that close to your family! Thats rare.
This coming season should be a good one. My aunt gets season tickets every year. Go Chiefs!
  • Replies 59
Rolls-Royce
You're an ME for Rolls Royce?? The car or the aviation?
Industrial Engineering.
Since this has turned into an engineering discussion, I thought you guys might like to know that I'm a Project Controls Engineer. Does that count? (But not a "real" engineer, of course) :lol:
Not a big deal, I just make sure the contractors are on time and on budget. And make sure they get paid!!!
Project controls, i like it! I'm getting my Masters right now in Industrial Management. Good news! I got my promotion today to move to Manufacturing Engineer Lvl 2. Hard work pays off. Maybe I can start building my own man cave now lol.
Aerospace
We make these engines (well the T56 version only spare parts as the AE is the newer engine)
You're right, hard work pays off... nice job on the promo!!!
Aerospace
That thing is sweet! We tore down a 16 cylinder prop engine in school, very impressive. Where are they located?
Thank you!
Aerospace
My job is to support those...Aerospace Ground Equipment.
Sorry for hijacking
4050 hp each engine :)
Sorry for hijacking
No sweat... :cheers:
  • 1 month later...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
