Cleaned and getting ready to sell
f00f0235825e3b814dba6e6fe99861fe.jpgb4082a65f8c7648209ceb5b9e7806c50.jpg282a9bf198dc2373545bce62bf501fb5.jpg
You forgot to clean the engine bay. It's very simple, you just need a few things.
Spray and soak everything with simple green. * When it starts to dry after a few minutes, rinse off with your water hose. Wait for everything to dry(go for a drive to speed it up). If it's still dirty repeat. Then when it's dry spray everything with Stoners trim shine.
*If there is caked on grease or oil, soak those spots with simple green, the scurb with a tooth brush. If it's really bad use a degreaser, but be careful around rubber and plastic, it can bleach it, but the trim shine spray can temporarily return it.
This is how to can even increase trade in value. I have done this and the appraiser gives a "holy crap this car is clean"(my 09 Mazda 6 got a "this is the cleanest car I have ever appraised for trade in, and I've been doing this for years") at which point you can, "yes, as you can see it won't cost you guys anything to recondition, you can stick it on the lot right now"
Edited by SnakeEyes
I'll see if I can buy that hear. Only thing I'm worried about is there are a lot of wires not connected to anything from the last guy who owned it
If it's not connected then there is nothing to worry about. If a fuse or relay is exposed just wrap it in a plastic bag.
If you go dig through this thread I probably posted a pic of the 30 feet of useless wires I ripped out of ny 67 firebird from its drag car days.
That's probably what I have to. 74323ee262cc4507aa57fbcf6f7ed64d.jpgeaa6c77e34c2e578ef84778719fd82dd.jpg
Not a bad lookin' Mustang...bet the truck looks a tad better though.
Almost got the control arm on my Cadillac. The parts are a comin!
Thanks. I loved that car. Miss it too, but my truck is my favorite vehicle I've owned so far. Super well-equipped and looks amazing IMO. It's so comfortable to drive.
What kind of cadillac?
That was a sweet looking Mustang. Hope you don't end up regretting the switch!
Thanks brother. I did so much body work to that thing to customize it. i really do miss it, but still don't regret it
Yikes - that thing screams, "INCOMPATIBLE WITH MA ROADWAYS". People would be breaking things up here in that, including parts of their own bodies ...
What a great car to have in CA, AZ, or FL though!
It's not meant to be a daily driver. It's a track (race) car
Ryan B.
Guess there are people out there that could afford such a thing ...
Edited by Jsdirt
I am trying to figure it out. Anyone looking for a 2012 convertible?
Last cars and coffee at IMS for 2017 [emoji1361][emoji22]
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
