TNBSC - the new body style camaro
How is your car? Enjoying it?
Ryan
Arg, why do I get on Craiglist. I don't need that gorgeous triple black E46 M3 SMGConvertible for 9K...... Remember, the SMG sucks those years......the SMG sucks those years. Oh crap, I'm off work next week. I have a bad habit of buying "toy" cars when I'm on vacation.
Here, someone buy it so I'm not temped.
http://tulsa.craigslist.org/ctd/5508783641.html
Edited by SnakeEyes
Never been a big fan of Beemers, but that there is a sharp looking ride.
Oh, it's a car dealer - stay away!
Edited by Jsdirt
Yeah, and those are expensive cars to keep running. The every 60k Mile service cost $1500. The two parts that commonly fail are a few $k or more.
There is one for double the price that is M I N T and owned by a BMW tech who just did the major services, with full documented history. If I hadn't just bought a car I would be looking at it to seal away except for nice days.
That convertible has nav, and the really cool thing about the older BMW navs is there a guy that makes new NAV discs for the older DVD NAV systems. He somehow made software that takes the maps and POIs from the newer maps and translates them to the old systems, even though official support and updates stopped years ago. It still looks like the old maps, but has all the information the most recent maps contains.
Edited by SnakeEyes
$3,000 parts ... YIKES! :noway: Not sure I'd want to own that even doing the work myself!
Although it seems these days GM is trying it's best to inch it's way towards those kind of parts prices. With $60k pickups I figure it's just around the corner ...
Well, not so much the part costs itself, it seems modern BMWs have an issue of having simple $5 parts in very hard to reach places. I heard today about the E39 chassis 540i have a common issue called the "timing chain rattle". Supposedly has to do with a part that is cheap, but requires 30 hours of labor to access. $5,000 repair by the independent shops. E36 M3 has a $4 Nut on the oil pump that commonly fails and ruins the engine, but you have to basically take apart the front half of the car to get to it. Edited by SnakeEyes
This seems to be the way most auto manufacturers are these days.
Ford's infamous engine they put in the Exploder has a REAR timing chain .. what a brilliant feat of engineering there! Total nightmare to replace. It jackshafts from another chain too. Think there's 5 chains total in that engine I'm thinking of. Forget if that's the V8 or V6 ...
Getting to the point where we'll be tossing engines for crate motors over a .50 cent piece of plastic they buried inside - will end up cheaper! :noway:
Edited by Jsdirt
Close to already happening with Varible Vale Timing and cylinder shutoff failures in several brands.
And anyone notice you can option a 4 cylinder Camaro over 40k now? What the.....(edit, see my next post before you look that up)
Edited by SnakeEyes
WOW .... :noway::noway::noway:
Driving is becoming a rich-man's sport! :(
Yeah but that's probably piling every single silly option available right?
Someone will do it. The 4 cylinder Convertible with a few options hits 40 pretty quick. Already seen some around that at local dealers
Edited by SnakeEyes
That makes more sense. I didn't realize it was a ragtop. I'd never buy one, I'm too funny looking. :lol:
Doesn't make sense to me! A 2SS Vert starts at $49,235! Edited by SnakeEyes
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
