7 hours ago, FootballCoach53 said:
Apparently I suck at this.  Fog lights didn't come on unless switched on and turned off with brights. I also need a new diode. I bent the hell out of mine pushing it in.
Welcome to the party. I still  haven't been able to install mine yet. Gave up. How many extra diodes do you have?
A big fat zero. I thought I was getting multiple from Amazon but they sent one. Heading to the hardware store tomorrow to see if they have one.
Got mine done today looks great. Did the fogs with high beams and cargo with reverse. Thanks to all who contributed to make this a breeze.
Show off... ???
I’ll be trying it again this week.
Show off... [emoji23][emoji23][emoji23]
On the fog light mod I pulled the plug out to make it a bit easier to push diode in. First corner bent the diode a bit. I straightened it back out then tried next corner and it went in smooth. Then I tested a the corners on the high beam wire. Once I figured out which corners were good it went in no problem.
Yeah. I’ll have to do that. I thought I had the diode in. I’m trying to get my fogs on at all times. I just need to double check which slots I’m putting it into...................... on the plug.
I did the same thing. On Amazon there are like 20 people selling packs of multiples and I order the single 1 for the same price from one seller. He was laughing his ass off I bet when he got my money. Either way paid the same for the pack of 50 or more
Edited by bdsilverado
On 9/15/2017 at 7:22 AM, Ravenkeeper said:
I took one of my smaller phillips jewelers screwdrivers to make a path for the diodes, or even one of the small common-tip jewelers to help manipulate the diode's way into place.
My diode mods, from picture above. 1N4004 diode mods (strip toward second pin/wire):
GRY1 to GRY8 - Puddle lights on with all interior lights
BRN26 to PNK26 - Cargo lights on with Reverse (reverse the diode for R lights on with Cargo)
BRN18 to BRN22 - Fogs on with High Beams (Silverado's Lows stay on with Highs)
There are others for Park/Low on all the time, Fogs on with Lows, Fogs always on, etc. Believe the entire list is in "$50 and under modifications" thread, could also be in this thread somewhere.
Had to find a recent list. I did mine by putting the stripe end in first, and a fine tip jewelers screwdriver before the diode, to make a easier path for the lead. BRN18 to BRN22 (stripe end). Push the lead we’ll into each pin, at least 1/4”.
Edited by Ravenkeeper
Thanks, brother.  I appreciate the help.  I'll have to unclip it and go at it tomorrow or Thursday, then.
Yeah, that was another thing that I had to do, to make it a little easier, unclip it.
So I didn't read all ht e pages but that is the mods for a 2016 sierra
I want fog with parking lights.
cargo with reverse
Oh and if any one knows the bcm ambient light.
Thank you
cargo with reverse
Thank you
BRN10 to BRN18 - Fogs on with High Beams (Silverado's Lows stay on with Highs)
Corrected my entry above, had wrong pins.
Looking through the schematics, looks like you'll have to jump BRN10-BRN22.
10-22 worked like a champ on my ‘15 Silverado. I also have 20 more diodes to pay forward. I got 25 but keeping a few for myself.
PM me for the diodes.
    • Maybe.   Maybe.   I don't want to be the one that needs help and can't get it when I need it. That is a legitimate complaint, and how they respond to those legitimate complaints is a big red flag to me.   I don't care how good the product is their conduct is subpar. Some people are fine supporting that for the sake of getting the product they want. I'm not.   To be fair, I haven't seen or touched their product in person to determine for myself the quality of it. I'm not offering any opinion on that either.
    • So if you do nothing and they act on their threats like death to America or Israel. And possibly a nuclear war. Whoever survives wonders why didn’t they listen? Or we do something like every President has said they can’t get a nuclear weapon. We’re at the 10 yard line and it happens the time is now or never. I think I’m ok with paying a little more for gas for awhile. It’s a shame that we now live in a world that’s so polarized.
    • 4-5-6 fails due to design.  Not enough clutches and not enough piston to clutch surface area.  Also the backing plate can bow.     I'd say converter is two part.  The design of converter chosen, and factory tuning of it aka slipping it in D (also L6) for AFM purposes, as well as locking it up in 2nd gear, sometimes 1st, also it will partially lock up at light loads.  All because CAFE/fuel economy requirements.  A billet converter on the stock tune might hold up better, but would still be subject to the stock tuning and how its designed to lock or partially lock.     The most baffling part to me, is the 2007-2013 6L80s didn't have the failure rate the 2014-2018 ones do.  I've been where I work for almost 17 years now, and I recall maybe 3 or 4 of the 07-13 transmissions getting pulled for something.  14-18 on the other hand, it was at a minimum one a month being opened up.    If I had to guess, I'd say the tuning for the gen 5 engines/6L80 setup and its fuel economy goals had a good bit to do with it.  Also, it was bankruptcy time during these years, so I'm thinking some cost cutting was done for the launch of the K2XX trucks.  See also now the 10 speed valve body issues (more cost cutting).  They blow out some mesh screen in the spacer plate, undersized check ball, and the feed limit valve was aluminum and wears out prematurely.         I don't think it was the HP jump from the gen 4 to gen 5?  The 6.2 in the 07-13 trucks was good for 380-400hp during its life/states of tune, and the 5.3 did 310-320hp.
    • All this might be worth it had we actually recovered enriched uranium, a WMD, or an actual nuclear deal with oversight. This is a flub of epic proportion, and they all know it.   $5.10 at a station reporting $4.99 last week. Here we go....
