Front rims get very hot rear stay cool
My take on calling customer service is that you won't piss off anyone with the possible exception of yourself.
I am already pissed off so what are you talking about. Are you telling me that If I called GM they would tell me to "F" off? What is your thought process when you post this BS.
I just want the truck fixed. I really don't want to go crying to GM and then GM will call this dealership and piss them off. Instead I sat down with the service manager and he drove it and he was able to duplicate it. Now they are working with GM to figure it out. This is not my purchasing dealer, I am very thankful that they gave me a loaner and that they are trying to figure it out.
  • Replies 70
This seems pretty easy to diagnose. If the brakes are dragging, the front pads will show excess wear. I would say find a new dealer if they cant figure that out.
The current dealership is doing everything that GM tells them to. GM apparently thinks that it is something within the brake electrical circuit telling the system to slightly applying the brakes when they shouldn't be applied?
Like stabilitrak is engaging at random?
Like ABS or Stabilitrak.
It's weird because I have gone almost a week without it happening and then out of nowhere it starts doing it again. I can always tell when it starts because it will shift crappy, have loss of power, and feel like it's going to stall sometimes when it's in 6th gear and V4 mode.
Edit: I couldn't image trying to tow with this vehicle in its current condition. That would be a nightmare.
Have you checked all the fluid levels lately? It's just a curiousity but specifically is the front diff lube full and in condition? Just something that popped in my head as a possibility.
I haven't checked the front diff lube. The dealership has has had the truck for almost 2 weeks now. I guess they are just as confused as GM about the issue.
I told them, let's start by reprogramming or reflashing but they won't do it without GM telling them to. Why does GM hold these dealerships back from doing their job. The dealer doesn't want to do anything without permission from GM because they want to make sure GM is going to reimburse them for the work.
I didn't mean to upset you. I went thru an issue with Chevrolet customer service that ended with them buy in the truck back. The experience was extremely frustrating. I was so pissed with their CS for simply not doing what they offered to do and I agreed to go along with, further dragging out the process. I had taken copius notes during phone conversations with CS which helped when presented to an arbitrator later. Good luck.
Why don't you just push for a buy back? Many have had to do it with the 2014. Just join the club & start new
I am.
Edit: Now where is my jacket?
  • 3 years later...
Hello all this is my first post!
It seems like this thread just died a while back with no resolution clearly described.
It looks like the OP may have gotten rid of the truck with this issue though.
I just bought a certified 2017 Z71 LTZ with <25k on the clock.
I have had it now for just under 3 weeks and noticed the EXACT issue described by the OP.
Both front wheels have EXCESSIVE heat but not every time I drive.
As described in the thread, it sure seems to me like some kind of intermittent electrical / computer issue related to the ABS / Stabilitrac that causes some drag on the front brakes at times.
I have a service appointment tomorrow to have it looked at but just thought I would post something here to share the experience as it plays out.
Has anyone else had this issue and was there any resolution?
So nothing found by the dealer.  Intermittent problems are the worst.
Got a laser thermometer to start logging what is happing.
Really surprised at having the exact same issue as OP but yet it doesn't seem like anyone else has had this problem.  We'll see what tracking this for a while shows.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
