Mods/Accessories under $100
LT Dan
  • Replies 59
Spidy Gear Truck Bed Web... $50.
GM-OEM-Chevy-Silverado-Cargo-Bed-Web-Net
Home Depot "Keeper" Flat Bungees... 24" and 48"... $3-$5 each.
Splash guards...$70 - $100. Can I get a "like" on this one? :lol::thumbs:
Looks very nice...as do the mud flaps. Another "like"!
We could use more service techs like that! Most look like butt-crack-plumbers. :lol:
I was thinking if the plumbers looked like her I think I have some pipes that need fixing.
I don't know why she needs a hard-hat for that job.... but she can wear anything she wants.... :thumbs:
...or doesn't want.
I think a guy could do a front end leveling job for under $100. Ebay has dozens of sellers of bottom shock spacers for less than $50. If you installed them yourself and took it to an alignment shop, I think you'd still be under your cap
Makes me think about just how dirty things can get. I'd really like to have a full set of 4 of those. But, I don't think my wife likes the way they look.
If you figure in the alignment you will be over
Alignment is around 60$ here is so cal... I wouldn't skimp on the spacer and get a decent one..
The ebay spacers I bought were made from a custom aluminum extrusion and milled on both mounting surfaces. They were supplied with grade 8 bolts. They were manufactured by a southern California machine shop who sells directly on ebay. I paid about $40. The most popular high priced kit uses plastic spacers.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
