Curious to see if they make any difference, I don't see any install points in the rear of the truck, can you install one and maintain the rear hitch?
Thanks
Could be wrong, but I don't think it would make that much difference. These trucks have so very little body roll.
With a shock upgrade it makes a huge difference.
Does the truck feel less wobbly? That's one of my tiny complaints.
Far more solid and stable feeling at all speeds, cornering, side winds, washboards, whatever.
Are those custom mounted brackets for the sway bar??? can you buy the kit without the shocks?
Those are U-bolts to the axle and frame. No drilling or welding required. The Hellwig anti-swaybar is purchased separately.
7735 Hellwig Big Wig Rear Sway Bar 2014-2014 Chevy-GMC 1500 2WD-4WD-1 1/8 Inch Diameter
The Hellwig Heavy Duty Sway Bar provides added sway control when hauling heavy loads or towing. Greatly improves cornering traction for safer driving and better handling. The GMC 1500 Rear Sway Bar from Hellwig Products features a 1 1/8" heat treated 4140 solid chromoly steel bar for maximum sway control. The adjustable rear sway bar and mounting brackets are powder coated for durability and good looks. Includes all necessary hardware and does not require drilling to install.
Chevrolet Silverado 1500 Fitment 2014
GMC Sierra 1500 Fitment 2014
FEATURES
•1 1/8 Inch Heat treated 4140 chromoly solid steel bar
•Polyurethane bushings
•Adjustable for desired amount of sway control and handling
•Easy installation with no drilling required
•Made in the USA
•Lifetime guarantee
Edited by crew62
What you pay ?
Retail Price: $366.95
Your Price: $282.29
+ 15% OFF SALE
Sale Price: $239.95
Free Shipping
www.sdtrucksprings.com
Probably closer to $500 if you have a reputable shop order it in and install it for you.
Edited by crew62
i have the same bar, but i am thinking about shocks.
are those shocks adjustable as far as compression and rebound?
what exactly was better with the shocks you got verses stock.?
What you pay ?
Your Price: $282.29
+ 15% OFF SALE
Sale Price: $239.95
Free Shipping
should have said what DID you pay, iphone typing is not my thing
The coil-overs up front are adjustable. The rears don't appear to be. I am guessing that the little silver plug on the bottom of the reservoir is for assembly, if it was for adjustment it would probably have arrows with + & - . I can't see the top part of the shock, but I felt around up there and couldn't feel anything that felt like an adjuster.
Years ago it was popular to say that the factory shocks you got on new cars cost them about two dollars. I've always thought that the factory shocks were cheapos (besides for Raptor shocks) and I have always noticed a big improvement with the handling when replacing them. I put these on about a week before I put the swaybar on and noticed a big improvement. You're asking for an 'exact' difference between the cheapos and a quality unit. It sounds like you may be concerned there is a downside to upgrading your shocks. Everything about it is much better. I does not ride rough if that's what you might have been thinking.
With the addition of the swaybar I noticed the biggest improvement. I was kind of wondering what it was like to add the swaybar with the factory shocks, but that really doesn't matter to me. Doing both is what's best by far IMO.
And for the other guy with the 'what you pay' grammar correction....no worries.
Quick Overview (no mention of adjustability)
Dirt Logic Shocks with Reservoir by Fabtech are designed for the ultimate in performance, custom fit and the best quality ride available. They are built in-house by Fabtech at their Chino, CA (not China) facility using CNC capabilities, quality control and off-road design experience.
Another outstanding feature of the Dirt Logic shocks is the use of electroless nickel plating for the shock body. Electroless nickel will not deteriorate over time by turning milky and blotchy. Because of this, no clear coat is required. Nickel is the best plating possible for a take-apart shock. This standard is superior to other shock that apply a clear coat over zinc that eventually wears or chips off exposing the shock to rust.
Dirt Logic shocks are constructed using seamless steel tubing, billet aluminum top cap and rod end with urethane or spherical bearing mountings. Stem applications use a chromoly stem instead of the industry standard clevis adapter kit. A dividing piston is used to separate the oil from the high pressure nitrogen gas to eliminate fading and retain a consistent ride. This is superior to emulsion shocks that lose performance quickly.
The aluminum parts of the Dirt Logic are polished before the black anodized finish is applied. This results in a smooth surface for the anodizing to coat leaving a deep black luster.
External reservoirs are used to accommodate additional oil and nitrogen volume. The additional oil volume helps keep the shock cooler. The additional gas volume helps to keep more consistent control forces over a variety of temperatures.
For complete compatibility, Fabtech is the only manufacturer that builds both the suspension and Dirt Logic shocks in house. This guarantees complete compatibility. Covered by the Fabtech Limited Lifetime Warranty.
Edited by crew62
Sounds like I may need to add this to my list of wants then.
    rayredbone
    rayredbone
  • Who's Online   4 Members, 0 Anonymous, 318 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
