I have a 3.5 inch Borla tail pipe and it clears perfectly.
RT
Which is smaller than the resonator..
It will clear the stock exhaust on the 6.2L
Thanks guys. I just got done installing the hellwig 7735 and it was nice and straight forward. My only problem is the spare tires is a bear to maneuver around the stabilizer and possibly the curt xd hitch on there. I had to fight with that to get it back in there. There was a ton of room from the exhaust. I wish the bar was an inch wider.
Sent from my SM-G930V using Tapatalk
Anyone have the Borla rear split dual exhaust w/ this sway bar? I don't see that there's a lot of room on the driver side to install it with Borla split exhaust.
Edited by camcamaro1991
I have it with the dual split exhaust. It does for, but that drivers side is tight! I had to modify the mounting bracket for that side. My build thread should have how I did it.
  • 4 years later...
Anyone tow a large travel trailer with and without the sway bar?  DOes it dramatically help with towing?
I would be curious if this a well
i'm almost set up to go towing in spring.  I got thr rear bar, but just recntly added the fat front bar as well. i'll let you know how it tows.. so far with this stiffer set up the truck loves to haul arse through canyons and bang the apex on long swoopy fast curves.  for a farm truck with a camper shell.. it drives with BMW precision  !
Edited by flyingfool
Can you share links to what bars you installed? Thanks!
using Helwigs Front and rears bought of Amazon , truck is all stock handles great now!
