2015 Silverado Vibrations?
TX1616
20Bowtie14, unless they did not know the driveshaft sound deadening material was the culprit. You may have replaced the driveshaft 3 times however if they did not fix root cause, they may have been 3 suspect driveshafts.
I wonder if there is an upgrade in the shafts or a revision that was made at some point in manufacturing.
  • Replies 48
I will say this, I've seen in on here and a couple of other forums now of people with vibration issues getting fixed by replacing the drive shaft.
Apparently there is some sound deadening material in the shafts and it is braking apart which causes the shaft to go out of balance..
So there may now be a fix that works...
I believe you are referring to this post.
http://www.gm-trucks.com/forums/topic/153186-shake-or-vibration-issues/?p=1480340
.................................................................................................I took my drive shaft to a drive line place to have the balance checked, when spinning up on the balancer, I could hear something inside the drive shaft bouncing around until just the right RPM and then the object stopped moving and the drive shaft was out of balance. We stopped the drive shaft and re-spun it. The same noise was heard and when the object stopped moving, the machine required a different amount of weight to balance the shaft. Each time we spun up the drive shaft, a different weight was required and some times no weight. What I found out is that there is a sound resonator in the drive shaft that prevents noise from resonating through the drive line, some drive line manufacturers use a cardboard cylinder with a seem cut in it and others use a rubberized foam. both are compressed, shoved into the driveshaft, and then are supposed to re-coil and fit tight. Based on the sound, it sounds like my drive shaft resonator was made of cardboard and has been progressively breaking apart every time I drive the truck. I have since taken my truck into the dealer and they are replacing the drive shaft. Hopefully this will be the end of this problem. I posted this in hopes that it could help others out there.
2014 Silverado standard cab 2wt v6 , smooth as silk . Just bought it and absolutely love it .
May 2014 build Indiana plant
LOTS of 14s out there that DONT vibrate, we get it , really, we do.
Those of you that have smooth riding trucks dont have to post it in the vibration threads, really, you dont. We got it.
It's funny that that is how you take it. THe reason why I am in the vibration threads is because I am terrified it will happen to me. Not because I am gloating.
If posting the build date can give anyone some sort of clue as to which trucks report the vibration, then I'd say that's solid info.
Settle down, sir.
Settle down, sir.
X2 well said and my exact feelings . Being a new owner I too am worried about this issue and I'm extremely happy I'm not experiencing it "Knock on wood ". But on the other hand I really really feel bad for those that are and can only imagine how frustrating it could be .
The main reason for my post was to share my info for a possible comparison to what vehicles are and aren't having the issue including there build dates and models /motor size .
I do understand though how a select few might feel frustrated because there having issues and others aren't and want to vent . It's also good to be advised of others that aren't having issues and like mentioned by a previous poster it really is a small % of vehicles doing it .
But if you come on to a forum and see some folks that are it can be alarming . You just have to remember how many 1000's of truck owners that are not experiencing it compared to the very small percentage on forums . I've owned many vehicles , Home Theater and 2 Channel audio systems using forums for knowledge and sharing our passions . But with that being said there's always going to negatives posts and unhappy owners no matter what , always.
Settle down, sir.
I dont go into every problem thread and post, "My truck doesnt do that".
Some people feel the need to do so. Other people see that and subsequently also feel the need to say, "Mine doesnt do that either".
Its not that Im unsettled, I simply dont care for it.
It derails threads, clouds issues, wastes bandwidth and usually contributes nothing to the original subject and then requires wading through all the "My truck doesnt do that" and "Hey I like your truck" and "What kind of lift and wheels are those" posts to read the real replies that do contribute and relay useful information.
Posts like that used to be called thread hijacking and it was frowned upon and people actually apologized for it at times. Now its just "I can post whatever I want and ******* you if you dont like it".
If you believe your 2014 build date is relevant to the original discussion,
2015 Silverado Vibrations?,
then by all means, post away.
I have no power over what anyone posts, Im merely stating my opinion. Like it or not.
You have a point regarding the 2015 thread. That's my bad.
I stand by my previous statement as to why posting the build date in a thread re 2014's would be helpful.
Please keep in mind you read about this issue here but the actual number of trucks out there with a vibration issue is very very small percentage.
Probably the reason GM is buying them back. If it was a big issue they would be handling it much different.
The people with the issue or issues in general tend to find the forums when they are seeking out help and support which we all like to give.
But it creates a picture of a bigger issue than it really is some times.
My truck has only gone in for to get a fog light replaced and that was just defective bulb. I noticed the first day I had the truck.
These are my exact thoughts and I've believed this since day 1 of owning my "no-vibration" 2014 crew cab silverado! This is what I've been trying to say, but you stated it perfectly.
BTW... don't make this statement over in the "Shake and vibration issues" thread! You'll get your head chopped off! I've already been called "Mr. Perfect-Truck!" :lol: (among other not so nice comments)... :cheers:
No worries Luster, we love you with or without a vibration.
What a relief! Thanks! [emoji3]
  • 5 months later...
so does that mean the vibration guys will stay out of every thread about a non vibrating Issue?
we get it, your truck vibrates. we get it
Damn dude, your one of the biggest nut swinging gm fan bois I have ever met.
In every problem thread you show up and contribute absolutely nothing but make people feel bad when they post a issue
Isn't it ironic that sometimes the least expensive truck such as yours turns out to be the least problematic one? Some posters here paid probably twice as much as you for their crew cab 4X4 LTZ trucks with the 6.2 liter V8 and have nothing but headaches with their trucks.
This is true sometimes simplicity is your friend :) I really do love this truck !
Hello everyone! I'm strongly considering selling my F250 and buying a '15 Silverado but have been hesitant mainly because of the vibration issues I've been reading about.
It's probably a little early but.....have you guys heard of anyone with a '15 that does, or does not have vibration problems?
Thank you
My 2015 is smooth as butter.
    btm
    btm
  • Who's Online   7 Members, 0 Anonymous, 1,422 Guests (See full list)
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
    • Just wanted to get a idea of how many of you still have problems with your radio cutting out during the first few minutes of driving, my 2024 GMC Sierra still does this after a little over 2 years of complaining to my dealer about it, and OTA updates no longer complete, the check for updates in settings is greyed out for the second time while trying to install a update, my dealer took about a week to play around with it the first time this happened, and somehow got the check for updates to work, even though it would always show system is up to date when I knew it wasn't, now again 1 month later its greyed out again when the OTA update N25-F163BU tried to install, which ironically is the update to help with reliability of future updates.
