6.2L emblems
Isriam
Looking to find some cheap 6.2L to place somewhere on the truck. Anyone have good leads on cheap emblems? Google/ebay didn't show much in my price range. Also looking for positioning opinions.
I think there is a previous post on this. If not, search on my ID + emblems.
eBay is your friend. My choice is upper front fender near A-pillar.
Good luck maybe try autozone pickup the individual numbers
If you want to step up to some high quality emblems check out emblempros.com
Ryan
http://www.ebay.com/itm/2-CHEVY-CAMARO-CORVETTE-6-2L-L99-LS3-LSA-ENGINE-EMBLEMS-BADGE-BLACK-PAIR-/360425931302?hash=item53eb0f4226&vxp=mtr#ht_5425wt_1144
I have these for my truck. I have one in my grill on the lower driverside like the z71 badge. I plan on debadging the rear and adding the other one to the lower right corner of my tailgate.
Can you tell me how big it is? I swapped a Z71 grille on my non Z71 truck so if this fits in that emblem spot that would be great!
1" high by 4" wide
  • 2 years later...
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
