Crew cab with 6.5' bed, regrets?
  • Replies 39
I guess you yourself doesn't have a real truck either then since you have a crew cab standard bed 2500 (3/4 ton). I've had an 8 foot bed before and never used it to it's potential I guess you could say. I mainly use mine for hauling and still only need the standard 6+' bed. The only time I had a standard bed and wished I had an 8 footer was when I would help someone move, but a big enough job they just rented a uhaul trailer.
Correct. I have a toolbox in the front of the box, and the small space left **sses me of all the time.
I still wish I had an ext cab long box.
I wouldn't mind another 8' bed, but I'm fine with the standard 6.5' and I don't think I would use the bed enough to actually need the extra 1'-1.5'. It's no way I could let myself have a short bed. For one, I need a toolbox and a full width (from front to back) and with a short bed I wouldn't be able to get a full width box. Also long beds are rare now it seems, at least with 1/2 tons. Before GM offered a crew cab and standard bed on the 1500s I said if I ever needed a full crew cab I would get a 2500 just to be able to get the standard 6.5' bed with a crew cab. A buddy has an 06 Sierra crew cab short bed and he doesn't even have a toolbox, but I would hate to see how much bed he has left if he did get a box (unless it was a narrow box).
I actually agree with you, but I couldn't resist after your dissing of those that like the 'short' bed.....
I know it's cool. I wasent dissing them just giving my thoughts.
You are correct about a toolbox with the 5'8" bed. A tool box in the short bed leaves just enough room for a beer cooler. Not much else. If you have a fish cooler, well, maybe. I was in the same mode of thinking 2500 series if I stayed GM. Problem was, if I did go that route, I'd have to get the Duramax/Allison combo just because. That'd been a lot more coin than settling for a Ram or Ford 1500 CC with 6.5' bed!
The 8 ft bed proponents always say:"you can't even haul a sheet of plywood in that 6 1/2 ft bed.
I say this: "I never had much call to haul sheets of plywood. But when I did, it seemed to get the job done. I hauled 150 sheets of plywood in my 6 1/2 ft bed when I did my roof. How many sheets of plywood have you had in that 8 ft bed?"
I installed an amp research bed extender to give me 8' when I need it...and a place to keep groceries when I don't. Without the 6.5' bed...I wouldn't be able to load all the bikes when we go camping. (full size mountain bikes are pretty long)
Drive my truck daily in NYC and I don't think I'd want to manage a 6.5 yet alone the full 8' (I know- not an option with a CC). First truck/SUV for me, but 10,000 miles in 6months has made me pretty good at parallel parking and general maneuverability thru traffic. I have a low-profile tool box/headache rack and there have only been a few times when I've had to drop the gate. The 10" of space under the box is invaluable though.
The truck's proportions look better with the long bed in crew cab. But if the primary mission is mall crawling and heavy hauling at the grocery store , then the short bed gets the nod.
What's frustrating is seeing how misaligned the beds are. You can see it by following the lower third body creases. The long es exacerbates it; not all have this problem, but the majority do. It's less prevalent on the 2500s.
No regrets from me. When this body style came out, that was exactly what i wanted, a crew cab and standard size bed. Finally got it on Veteran's Day, very fitting for me for the day and deal I got it for.
Well actually 1 regret, somebody already swiped my driverside taillight and scraped the bed. But that is not my fault.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
