Bilstein 5100 adjustable ride height
5RWill
I've called Bilstein and was told the 4600 is the same as the 5100. The 5100 is for lifted trucks and is 1" longer than stock to make up for the lifted height. If you install a lift kit it will give you the same compression and rebound. I do not think the shock was made to lift your truck by itself. I'm sure it will, but I in my opinion it is adjustable to make it the same as the stock settings. I think lifting your suspension to it's fullest is not good by any means. It would be easier to put coil spacers like the old days. I'm going with the 4600. I'm not against the bigger tires,I would love to have them,but not going for the lift kit.
Don,
If you aren't looking for increased height nor off-road performance, I think the 4600 is the way to go too.
The 5100 is designed to provide lift by itself. On some makes of trucks, up to 2.5" of lift. On the GM trucks, up to 1.8" of lift in a choice of 4 heights.
  • Replies 129
Spurshot- you seem to be pretty knowledgeable so I'll ask here. There's about 4 other threads on this and I can't seem to find my answer.
Will the bilstein 5100 set (front and back) play nice with a RC 2.5" leveling kit? (Sorry, relatively new to the lifting game) and no, I don't have the rear block installed. Thanks!
Short answer is yes. Set them at the "0" lift groove or you'll be over extending the suspension.
However, If I were looking to use the 5100 and absolutely had to have 2.5" of lift, I'd set the rings in the 1.85" lift groove and put a 3/8" thick spacer under the lower mount of the shock. This will limit the unloaded extension of the A-arms to less than using a 2.5" (1.25" thick) spacer as you proposed (which may protect the upper ball joints from damage)
That helps. Thank you. I've ran into 2 others looking for this answer.
I wasn't exactly planning on using the 5100s as a "lift" so keeping it at "0" was the plan anyway. Just interested in the performance and ride quality.
Thanks again!
If you're not going to use the lift option then just get the 4600. Same shock but not the grove options. That's coming from Bilstein.
Pop Bilstein told you the 5100s are an inch longer than factory struts or oem ranchos per say?
Yes,there is a post on the difference between Bilstein and other ways of lifting your truck. I'll try to find it later. Got to go shovel snow...
I mean the actual length of the strut. Is the Bilstein physically longer than the factory or oem ranchos.
It is longer. I didn't measure it but you can see the difference in this picture.
2015 01 09 19.21.02
DCarl was there any height difference between the Ranchos and Bilsteins installed? Did you measure height with just the 2inch lift and ranchos and after bilstein install?
Any thoughts on Rancho coil overs RS999901 with adjustable ride control for a 2 inch lift. I talked with rancho tech they said that the ball joints would be within limits for this application. What I like about these is there are 9 levels of adjustment for ride control from soft to firm. The rear shocks RS999198 also adjustable.
I found a thead on this topic after posting this question but will leave it here for any thoughts.
  • 1 month later...
http://www.gorancho.com/products/leveling-systems/quicklift-7000mt-leveling-system/rancho-quicklift-7000mt-rs7831.html
I'd go with the 7000mt though guys are running the quicklifts with success.
My rears came in. Do the snap rings come with the fronts or is it the one used off of the factory struts? None came with my fronts.
Two weeks when i come home again i'll get everything installed, remove the front air dam, and running boards.
Yes indeed, 100rds of lapua .308 and probably 600rds or so of random 40S&W. There is Dillon 550B still in the box to the right of cabinet. Been trying to get a reloading setup going for years. Finally cleared out a room just need to build a bench.
    doylej24
    doylej24
  • Who's Online   5 Members, 0 Anonymous, 744 Guests (See full list)
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
