Bilstein 5100 adjustable ride height
5RWill
These billstiein shocks look interesting. I was planning on a1.5" spacer but these may be better. I assume that a new alignment is needed after adding them? How easily adjustable are they? If I tried them at 1.8 but wanted 1.2 is that a big deal to change? I want to raise the front end but still want a slight rake. Completely level always looks front high to me. Thanks.
They are adjustable via groves in the outside of the shock body and you have to have the spring compressed to move where the spring pocket sits. It's not as easy as turning a dial, but I would think it could be while installed if you have a spring compressor tool to use. I haven't installed them yet but I will be, so someone who has actually installed them may want to chime in as to how difficult it would be.
As far as alignment, YES, it will need to be done. It's all over in these threads, but any suspension work should be followed by an alignment, and especially so on a IFS/multi-link style design.
  • Replies 129
thanks. Can anyone tell me what is the exact part number I need for the adjustable front shocks? Apparently there is a new style and and old style and I think I need the new style. All the websites say this part is not available fro my vehicle. I assume that we are actually using a pre-2014 model shock? Thank you!
I've got the rears....still can't decide if I'm going to do the fronts...I didn't notice a huge difference from just the rear swap out with the stock ranchos. Do the fronts make a more substantial impact or no?
They definitely did on my 2011. I have the rear on my 14 also and just ordered the fronts today. By the way if anyone is interested I came across a smoking deal on the fronts today. Streetside Auto has them in stock for $89.00 a piece with free shipping. I ordered them this morning and they shipped same day.
I have never used this company so cant vouch for them but spoke with someone on the phone today who was helpful.
www.streetsideauto.com
They are showing soldout already.
I had entered my email to be alerted when back in stock. Took a week or so. Still best price I found.
Well just ordered a set from suspension connection for 413$. Bit more than i could've gotten them weeks ago but said it would ship monday so i thought meh.
Will let everyone know the dimension, ride, etc. when i can get them installed. My have to wait until the next paycheck for the installation.
I have a rough country 2.5" lift which is a 2" spacer under the shock 1/2" spacer above. why not set the bilstein at .6 and run the 2"spacer? My ride hit should be really close to the same it is now
I'm interested in doing the same. I have the 2.5" RC kit with block in the back and I think doing the above would improve the ride and reduce stress on CVs and balljoints. Anyone have experience or know if adjustable shocks and a spacer is ok to do?
I have an AT Sierra and its my first GM truck. Coming from a F150 I was expecting a smoother softer ride as everyone says, but the ranchos are very stiff over speed bumps and uneven surfaces. On a smooth surface the truck handles just fine though
I've seen people strongly recommend against using the height adjustable seat on the bilstein and spacers. Though i don't see why you couldn't use the stock setting and spacers. I still think the bilsteins are longer than factory OEM shocks and will give a solid 2" of lift. Pro-Comp offers their ride height adjustable shocks which can be stock or 2.5-2.75" with the spring seat collar inverted.
Whats the thought of bilstein 4600 VS 5100 for the best ride possible. The stock ranchos are fine to me on the highway but to stiff on small town streets with potholes and wash boarded gravel roads. On the 5100 if you use the first position lift would you have to have a front end alignment.
Thanks
You would definitely have to have alignment either way when changing struts. The 5100s are said to be more stiff than the rancho oem shocks. My oem ranchos are bouncy to me. Ride is still very good but they are bouncy when going over ruff terrain. The 5100s are supposed to be more controlled and more firm.
I think the 4600 is for the hd trucks is it not?
Thanks
Your take on the OEM Ranchos is the same as mine. Too stiff to keep contact with the ground on the bumpy stuff and a poor ride quality.
I had the 4600 series in a 99 1/2 2500. The ride was good. It was a bit stiff. But nothing like the OEM Ranchos we have in these 1500s. From the reading I've done, the 4600 is supposed to be a general purpose shock that is good for towing and street use. Of course, the 4600 has no height adjustment. The 5100 has a softer dampening to allow for off-road use. I had 5100s in my 2008 1500. I thought they could have used a bit more damping in the front when on the freeways. It had a bit of a "floaty" feel in some situations at freeway speed with bumps. But, they are balancing off-road tire contact against street control. Contrary to what some may think, off-road shock damping is a fairly low level of damping to allow the suspension to move more travel, more quickly than street shock damping.
I've called Bilstein and was told the 4600 is the same as the 5100. The 5100 is for lifted trucks and is 1" longer than stock to make up for the lifted height. If you install a lift kit it will give you the same compression and rebound. I do not think the shock was made to lift your truck by itself. I'm sure it will, but I in my opinion it is adjustable to make it the same as the stock settings. I think lifting your suspension to it's fullest is not good by any means. It would be easier to put coil spacers like the old days. I'm going with the 4600. I'm not against the bigger tires,I would love to have them,but not going for the lift kit.
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
