Bilstein 5100 adjustable ride height
5RWill
If your tires don't clear without a leveling, they won't clear when you drive it. Either pick a tire that fits before leveling (if you don't want rubbing/trimming) or it will rub when you turn and cross humps in the street or bumps on the dirt roads. 2" is nothing for your suspension to compress. Just turning onto another neighborhood street at low speed will do that.
  • Replies 129
The "old version" of the 5100 gave about 1.8" just like the new one. I had a set. The specific instruction said the lift was 1.75 or 1.8"... I can't recall which, but it was a big question around this forum back then too. The general advertising for the 5100 shocks stated "up to 2.5" of lift". But it was model specific. I think the Toyota 5100s were 2.5", but the GM 5100 was always 1.8".
So don't waste your money on the old 5100 for your new truck. Take advantage of the new valving specific to these trucks.
On the tires, I put my (actual spec) 32.6" x 12.2" (Cooper 305/60-18 (also marked 33x12.50x18)) tires on stock rims on my truck at least a month before I picked the front end up 1 1/2". They never rubbed.
Yup looking back i now i see that the old ones are only 2" as well. Looking at that link i posted i thought it was certainly 2.5".
What were you dimensions before and after? 295/55/20 are only supposed to be 32.9x11.6x20 technically speaking, if i could fit those with 1.8" of lift i would do so. Did you run yours max? I was wanting to know if it's true about the rough ride on the highest ride height setting.
**Ride heights indicated are typical. Actual ride height is influenced by which factory suspension the vehicle is equipped with and its condition;"
I wonder what the actual difference is that is "influenced by factory suspension"? I saw that the other day and wondered if that means it will be a different height for a z71 vs non. Or am I completely off with that thought?
-Skeet
I see. i don't honestly know if i can clear 295/55/20 to the naked eye i would think so. I have a good bit of room with the 32" stock tires that come on it.
Easiest way to know is to measure it. A stock truck with stock tires is a good place to start.
Start the truck, turn the steering wheel all the way one direction to the stop, run the driver seat all the way forward, loop the seatbelt thru the steering wheel or get a second person to hold it to the stop, leave it running. Get in the wheel well and measure your clearances with a ruler. It's simple math to figure out how much larger a tire you can fit or what offset will work. This really isn't difficult.
IF YOU USE A SECOND PERSON TO HOLD THE WHEEL, MAKE DAMN SURE THEY KNOW YOUR LIFE DEPENDS ON THEM NOT MOVING THE STEERING WHEEL WHILE YOU ARE IN THE WHEEL WELL. (SEAT BELT IS SAFER)
My oe shocks are the red and white Ranchos. Would i see a benefit? Smoother ride?
Yes
Yes
What would be the lowest setting you can set the ride height at? 1.8" isn't fully leveled so I figured if you can set them at .5" maybe you can stack a 2" spacer? Not even remotely sure if that'd work never dealt wtih shocks. Lol
You can set the bilstein 5100 from 0 lift to 1.8" lift in 4 equally spaced positions.
So roughly: 0, +0.6", +1.2", +1.8"
If someone absolutely had to have more than 1.8", I'd say set the shocks to the max (1.8") and use a spacer to get the additional height. Keep in mind, bilstein chose 1.8" for a reason.
The only reason I'd like more lift is because at 2" my truck doesn't sit dead level so at 1.8" I could only imagine it'd sag more. Would it be a better ride if they were set at 1.8"? For some reason I figured if they were set lower they would ride better, but like I said I don't know much about how shocks work.
I've been wondering if i could somehow acquire that 1/2" spacer from rough country to put on the top of the strut and use the bilsteins at 1.8". 2.3" would in reality be perfect. Though i've always read against using spacers and ride height adjustable struts. I would like to hear bilsteins take on why they went with 1.8" for max height. I need to get under the truck and measure like you said spurshot to see if i could fit the tires anyway. Though at 32.9" almost exactly an inch bigger than my current tires i think i do have an inch or so.
I would like someone to let us know how they ride on max height setting to confirm or deny whether it's rough or not. I had heard they're rough on the max height setting.
Could add this bottom 1/2" spacer.
http://4x4.fatbobsgarage.com/chevroletgmc-1500-pickup-tahoe-suburban-12-leveling-kit-2007-2015-p21675.aspx
When using spacers, the ride height change I'd roughly twice the spacer thickness.
How much you lift with a spacer or shock changes the CV joint angles as well as ball joint angle at rest and in the case of spacers, the extended A-arm ball joint angle. The limited upper ball joint angle of these trucks is legendary. Exceed the limit of the upper ball joint angle and the joint will loosen and give premature tire wear. The many aftermarket upper control arms are targeted at addressing this issue.
So the upper ball joints have little room for any kind of angle? I've noticed at 2.5" the upper UCAs looks pretty much maxed out. Honestly probably need new ones if running over 2.0" which is probably why the Bilsteins are 1.8"
I thought that was only if you used the spacer on the bottom where the shock connects to the lower control arm? Like the rough country 2.5 kit comes with a 1" thick bottom spacer that gives 2" of lift and then a half inch spacer for the top. Maybe I'm mistaken though.
I have a rough country 2.5" lift which is a 2" spacer under the shock 1/2" spacer above. why not set the bilstein at .6 and run the 2"spacer? My ride hit should be really close to the same it is now
These billstiein shocks look interesting. I was planning on a1.5" spacer but these may be better. I assume that a new alignment is needed after adding them? How easily adjustable are they? If I tried them at 1.8 but wanted 1.2 is that a big deal to change? I want to raise the front end but still want a slight rake. Completely level always looks front high to me. Thanks.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
    • Same here, first I bought a few filters to get me going right after I bought my truck to do some short distance initial oil changes, then realized I could buy a case lot for less as they drop the price if filters or trans oil etc is bought by the un opened case lot as well as the discount for buying the vehicle there. So I have filters for a while but its good to know going forward, knowing to expect it to be a different part number and looking filter at the dealer and not be confused over it and think they are handing me the wrong part.
    • Saw Inglewood was in the National New last night for hail. Allot of hail. front end loader level hail. 😱
