Is my fuel pump a whiner?
This morning driving to work, after being on the road for about 5 minutes, I heard a whining sound from the rear of the truck, sure sounded like near the fuel tank area. This happened again two more times about five minutes apart (my total commute is 40 minutes). Each time it lasted only about five seconds. It happened again as I was leaving work, about two minutes after I started the truck. Note that in the morning the temperature outside was 19 degrees, and after work it was 26 degrees. No performance issues at all, engine still ran smooth and strong.
It isn't rear-end howl, nor wheel bearing chatter. I can't think of anything else that would produce this noise back there. I'm looking for ideas.
The truck is a 2006 GMC Sierra K1500, 5.3, 4x4, X-cab, short bed, SLT, trailer package, Z71, etc., with 140,000 miles on it.
I don't think I have any water in the tank, although that is certainly possible.
My main concern is if this is a precursor to the fuel pump giving up, then I'll get it changed quick before it leaves me stranded on some logging road somewhere.
In the experience of this group, is this whining noise something that predicts imminent failure of the pump? Just cold weather? Contaminated filter making it cavitate?
The times it happened the truck was moving, but at various speeds, (35 to 70), but it was a very fast, high-pitched whine, sounded the same, not seemingly related to vehicle speed.
I'll be checking the pressure this weekend if I can, (can't do it before that) but I'm concerned if failure is likely the next day or so.
Turn the ignition on, but don't start the engine. Do you hear it?
It will also tend to be louder when the tank is closer to empty.
Mine whined for about a year before it died. It tended to whine the loudest on long road trips.
Guys, I am really sorry to have wasted your time with this thread.
Number one, I should have "searched" before posting, I would have seen the other threads on this subject.
And "B", It wasn't anything to do with the fuel pump. It was the rear end. And the Grenade 80 lived up to its name, it blew up today.
I left for work and it started whining about three miles down the road and I hit the brakes to see if the sound changed with vehicle speed, and sure enough, as I slowed, the sound lost pitch and volume and stopped when the truck stopped. I made it to work, and then the same thing happened on the way home, again after about two miles. When I stopped at the local post office, as I pulled out of the parking lot, there was a loud crunch sound and for about three seconds or so, I had no drive, it was like everything was slipping. Then it grabbed again, and I limped it the last 1.5 miles home making weird noises.
Thinking back, about a month ago I was on some slick dirt and I remember the locker taking a couple of quick hits in a row, and I'm sure now that precipitated this. Oh, well, I half expected it given the number of failures I've seen here and on other parts of the interweb.
I'll have it towed to the dealer tomorrow and see what's up.
Well at least the truck still got you home. Once you get a chance to get it looked at, let us know how it goes. I'd be interested to see what may have happened in there.
If you plan on keeping the truck for a while Id look into getting an aftermarket locker like a Detroit or if you don't care just put and open diff in there.. One of my old gmt800's didn't have a locker and it was nice to not worry about it
Sorry about your gov-bomb. All 3 times i've heard that noise i've lost drive. Its like putting nails in a blender. Then you stop, foot off the gas and the speedo reads 25 mph and you aint movin
Well, I was wrong on both counts. Not the fuel pump, and not the G80.
After having it flat-bedded to the dealer, they got looking into things and the rear end was fine. Turns out the transfer case was the culprit. The technician showed me the oil they drained out of it, it was so full of metal it clanked when poured. Not just little sparklies, but pieces of steel and aluminum. A bearing and other things had gone bad. I didn't waste money and time having them tear it apart, it's not something I wanted repaired or rebuilt. I needed the truck ASAP and had a new unit put it. Not only did it fix that recurring "SERVICE 4WD" light I had been getting for some time (gee, ya think?) but also cured that annoying drive-line clunk that has always been there. The old transfer also made a LOT of noise when shifting, a kind of grind and clunk and groan. New one is slick and smooth, just goes "whiirr, click".
On another note, while it was in the shop (two days), I rented a 2014 Silverado Crew Cab LT. NIIICE! I really hated to turn it back in. I liked it a lot but not enough to spend the money to get one.
I had always wanted a a new '14 ever since seeing it unveiled. When I went to the dealer looking for a new truck I was actually looking for a used Silverado, but they can't keep used trucks and the only full size they had was an F150 so that wasn't an option lol. So I started looking at the '14s and of course he had me test drive the one that met what I was looking for and fell in love with it within 1 mile of driving it. I couldn't say no after that and worked out a pretty good deal. I'm really glad I got it. It's exactly how I'd want a truck other than I wish it had Bose (the non-Bose system is still really good) and that it has 3.08 gears which I plan on changing.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
