do you think that size will clear on 0 offset wheels?
going from 22s to 20s and a slightly larger tire, should improve my ride
Yes, it should but you may ask your tire store if you can switch them out if they don’t clear. It’ll definitely improve going from a 22” to a 20” but you may want to consider 18”’s. 0 offset will stick out a tiny bit more.
Remember, E rated tires will ride much rougher than P rated cause they’ve got much thicker side walls and just over all much heavier. I’ve got my KO2’s aired down to 35 psi which helps a bit on comfort but some people find mpg loss airing down. I’ve got Bilstein 5100’s front and rear which helps too. Just for you to know: Fox Shocks will definitely give you a much stiffer/harsher ride then the Bilsteins.
had E rated on my sequoia, ride was fine. bfg kos in 285 are D rated. stiffer than P but should be fine
My 275/60/20 are D rated, 285/60/20 are E rated.
51 minutes ago, jgraves13 said:
What lift and wheel/tire setup is that?
Zone 4.5. 295 trail grapplers on 18x9 fuel kranks
If it were me, I'd go with the polished or chrome finish. Black or black/milled are just overdone to me.
2 hours ago, kylant said:
help me choose wheels for my leveled white denali, which ones?
Are they the same offset? I’m going with Daly with the polished look.
My 18 looks much better without the overdone chrome. New Fuel wheels not only look better but much easier to clean.
SOTA_truck_REHAB_dm_6_lug_20in_std-1000.thumb.jpg.6a2c7a72bb23a0e23d188b424170b690.jpg
Cheesy, non of the above
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
