Spent a week polishing and waxing before winter came. First time living in a snowy climate so keeping it clean is way harder.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Nice! Is this leveled? What size G2's? Nevermind, I read your earlier posts.
Edited by skcihs
My 2017 Sierra. The 6.2L is my favorite thing on this truck, I cannot believe how quick an almost 6000lb truck can be. The interiors are also so comfortable. Love it, my first full size truck. leveling kit and larger tires in the near future. I'll go with either 275/60/20 Nitto G2's or Duratrac. Both weigh nearly as close to stock compared to BFG AT's and slighter larger tires that go into heavier load ranges.
I thought it might be fun to post a few pictures of my 2017 Z71 Midnight in less then a shinny state. We have had 41" of snow in 3 storms this week.
The first picture was taken during a 24" Blizzard.
wow that's a great picture love the midnights
Side / Rear
I have seen your truck in many different parts of this forum Love that Matt finish you got
Finally figured out how to resize a photo on Windows 10 sos why not lol. 2015 GMC SLT AT 6.2L. 30" lightbar mounted behind grill, 33x12.5R20 Pro comps, AFE intake, Morimoto HID retrofit, full LED interior/brake light swap, Morimoto fogs (to be instaleld), tinted, "custom" leveling kit, magnaflow muffler, 15,000 miles
Possibly to come: Coilovers, Procharger, electric cut out, Kooks LT and dyno tune, low-pro vent visors, smooth and paint flares. Still deciding if I should keep for a five more years or trade when the new ones come out.
I keeping my, till the NEW body style comes out 2019/2020 I think.
Didn't do a whole lot with her, this morning, after work. Tried to tint the top of my windshield, but first pieces ended up not sticking, will reattempt in the next few days. After that, I detailed the inside, cleaned the windows (in/out) and dash-glass, cleaned the water marks off the chrome parts, removed my wife's makeup residue from the steering wheel controls (HOLY CRAP, I CAN SEE THE ICONS AGAIN!!!), and wiped the dust from the dash, center console, and doors.
Will post pictures when window tinting is done.
Edited by Ravenkeeper
6" BDS, 22x10 Fuel Titan rims, 35x12.5 Nitto Ridge Grapplers
trimming that valance up a little would make such a huge improvement!
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
4.5" Zone
22x10 AF Grips
The shop that put the lift on cut the valence for clearance on the angle but I'm thinking of just taking it off completely
that would look much better too. Either trimming it up or removing will be a HUGE improvement
Like that if you didn't wanna remove it
4.5" Zone
22x10 AF Grips
Edited by wildchevys
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
