2014 chevy 1500 Block Heater sucks
There is a resistor built into the cord on the gmt900's near the plug end. It's raised and about the size of a dime. Cut the cord end off and splice in an universal end and the temperature turn on and off will be removed.
  • Replies 33
I don't even bother plugging mine in. -30C today, and it started the same plugged in, as it does unplugged. The block heater works about as well as my heated seats.
  • 3 years later...
Bought a heavy duty extension cord from Home Depot.  As you stated, I cut off the Thermostatic cord end and spliced it to the heavy duty cord. Soldered the splice connectors and taped them up good to water proof them. Next I ran the extension down the truck frame with the cord end tie wrapped next to the rear trailer hitch. Tie wrapped the extension cord to the frame alone its run to keep it secure and out of harms way. When its cold out I plug it in to a heavy duty timer in my garage, set for a couple hours before I get up for work.  This allows the truck to start super easy. Easiest of the Motor and Battery with the benefits of preheated defrost air that not only keeps my windows clear of frost and ice, but the interior is already warm! As I step out of the house I also remote start the truck to positively pressurize the trucks interior to keep out the blowing snow and cold air...  The wife just loves that, heated seats and all...
Anyone modify the cord with a plug on the 2xxx's (location). The zip tie holding my block heater cord in place broke last winter because there was a lot of -30 days. Now I can't find a zip tie small enough that's also a quick release.
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
