Project Magneto is a success!
Dangerdick
those deaver springs are for 2wd that they offer, and from deaver's website they have them for the 2014 but it is also the same as the previous generation. I am sure the weight and loads of the previous generations are different from ours.
the front shocks are also for the previous generation as our year body would need different valving, and same for the kits with the control arms. they don't fit properly in our trucks if we use the old model parts.
none of those raises it nearly remotely close to the 7" height he has either.
until somebody comes out with properly designed parts for these trucks and not just slapping on parts because it "fits", that is not reputable to me.
but thanks for letting me know, i will periodically check their site.
The coilovers are the same as previous years because suspension setup is the same and there were no drastic changes in weight or suspension geometry to warrant a different product.
The 7" lift the guy has has no gains over a 3" coilover/deaver spring setup. As I said in my original post, since he using a drop-bracket kit with a giant sub-frame brace there is zero increase in ground clearance aside from that gained from the taller tire. Because of the drop-bracket kit suspension travel is the same as oem and offers no performance gains over a factory setup.
I get some guys like the real big drop-bracket style lifts but its just seems like such a waste to me if it offers no improvements. You loose a ton of mpg, ride quality suffers, and loading anything into the bed is pretty much useless now.
To each his own though.
None of those work on the magnetic ride suspension.
Of course not. I never said they would, however these would all be better lift options vs. a drop-bracket style kit.
Your truck looks great Danger! As long as you're happy, that's all that matters!
Looks good. Just please. For the love of God, don't put a hood like the one on the ferd on that Denali.
Awwww come on, that hood looks pretty sweet lol! Not sure how it would look on the Sierra, but I like it on the F150.
Had the exhaust done today. Flowmaster 40 with dual tips, single side exit. Snapped a few pictures of the shock extensions for the magneride system as well.
Please change that muffler. Flowmasters use a baffled design which blocks the path of the exhaust gasses. Your factory exhaust had a straight through muffler design. You will lose power with the flowmaster.
Henrypbui Mazzulla offers 2014+ longer travel suspension kits.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
