thx smcgillis10
take a look on the post from cotton_m number 11 we can see this switch with a light .....maybe another switch model ?
i would like to order this switch but need the light loll
if someone have an answer to solve this . i take :)
There is a light. Haven't plugged them in yet tho. 650b200d8bcc01cec8c618a0ef96c2c9.jpg
all is good so :) thx friend
i will order it tomorrow
this switch is 80$ in canada but i will probably have it at a lower cost at my dealer
another question .is aux 1 to 4 are the same way writed?? i mean i want to see if i can erase the letter and dig a symbol like fog light then i will just need to fill it with white paint so this way i can customize those switch .......maybe i explain bad (french canadian here lol)
finally i will have my switch solution ... thx upfitter
Edited by ravageur1972
Just got them. And my truck wasn't fitted for the switch so the wires aren't there. So the other post about the blue/green wires don't apply to all trucks. Only trucks with the option installed. So I soldered two connectors onto the board to get a connection point. Each connector has two wires and each wire will go to a different switch and relay. Pins 10-14 are for he aux switched. I'll post a pin out. c0df3b596b45e5f906ef35f0beaf93c9.jpg09a2996216424c446a1bb898f3ac4a0a.jpg41b1ff6b073613b0f667a3bd01b9dcda.jpg8c1932cd7d0e74aaae999e195812c640.jpgc1f5aea365d9f3a612ec63496f1cbf89.jpg29668bc92941f1cc93f786c2192ce79e.jpg
There's many different switch panels. But be aware the only ones you can hook a relay up to have the latch switches.
The momentary switches will only be used for small voltage actions controlled by the BCM.
These are momentary (the same kind the remote your tv uses) very low amp. . 6691d94bf5f83064c0d55d13983acd11.jpg
I'm kind of confused, Can I use this aux switches to turn on a light bar?
Yes. Have to use the aux switches to operate relays. Hook the negative side of the relay coil up to the switch.
  • 5 months later...
Okay I have a 2014 Silverado 1500 LT. And I bought and installed the switch. Where do I find the relay so I can connect my light bar to it? Also I'm confused on how to install it. Thanks
I was able to locate the GM Part number for the pins that fit into the harness that plugs into the back of the Aux switches. I will post pictures and part numbers tomorrow. I found that this would be better as it uses the factory harness and I don't need to solder on the inside of the switch. The wires would then just connect to the Negative side of a relay coil.
For most of you you don't want to put holes in your new truck. I have a solution for you. If you haven't seen it already.
On some of these trucks (ie work models) you can get upfitter switches that go where your traction control and cargo light switches go.
Trucks with only "traction control" & "cargo lights" can use this. ( if your truck has bed lights or a park assist it won't work.)
Looks like this d853e64d9587972cc5b975e6404df679.jpgthe empty switch is just a blank. (Does nothing)
This switches are ground controlling. So you can hook them up to the negative of a relay. Mine are on the way and I'll take/show how it works.
Unless your truck was equipped with it the factory delays and wires won't be there. Have to add it all in.
Sent from my SM-N920V using Tapatalk
  • 3 months later...
Does the blank switch actually have a switch behind it or is it fixed?
My truck has the bed/cargo lights, traction control, and hill assist. I'm wondering if the blank could be configured. If not I could go without the hill assist. I don't really see a need to turn that off. Anyone feel free to correct me if I'm wrong about that. I also think that if it is on when I swap switches out that it would stay on.
Do you still have the part number for this? This is how I was wanting to approach this too. Just run the four wires to a relay panel, then I can wire the relays to my devices.
Yes I do, and sorry guys that I never posted the pics I promised. I had a lot come up and forgot. I do not have the numbers and pics on me right now. But as soon as I get home tonight I will put them up for you
I just posted this on colton_m's original post...
I think that I have found a solution for using the OEM Momentary switches to control accessories such as light bars. I have decided to use the 23145202 switch as I have the adjustable pedals. This switch gives me 3 open slots to use. The issue with the switches is that being momentary they will not operate a standard relay. Upon searching I found these latching relay boards that come from China and cost $3 each. I picked up four of them to try, they are 12V boards that use a low input, so when the input is grounded, the relay activates and latches, until the input received another low signal. I assembled 3 of them in a case made a harness for them.post-153411-0-42461900-1453601410_thumb.jpeg
I am modifying the switch to have the correct icon too. post-153411-0-19740600-1453601459_thumb.jpeg
    • We live in a world where the average person expects more. People say wages and our needs are farther apart. My first new home had 3 bedrooms and one bedroom. My first car and truck had what would be considered a stripped or work vehicle. In my neighborhood back then there were more homes like that and cars too. Middle managers and second home buyers worked their way up to the fancy houses and cars. Car loans were 3 years. GM had different models of cars for different income levels. The cars were pretty much the same size if you wanted a big vehicle. The nameplate designated the opulence. Chevy, Pontiac, Buick, Oldsmobile and Cadillac.  To be fair some of the cost is government mandated. We can’t blame them for giving us what people will pay for. Careful advertising steering people towards more profitable SUVs and trucks. As I learned recently a minivan is a cheaper more efficient form of transportation. Certainly easier to live with. Somebody realized the profit margin wasn’t as big and gave it a soccer mom label. So it lost its coolness. They’re making it the masses are buying it. You hit your hand with a hammer you can’t blame the hammer.
    • Hi All, I’m In need of advice regarding a scan result on my 2023 Silverado HD.  The Sensor Supply voltage relay states ON But…. the following 3 tests show Malfunction. Sensor supply voltage relay control circuit HIGH voltage Test status- Malfunction Sensor supply voltage relay control circuit LOW voltage Test status- Malfunction Sensor supply voltage relay control circuit OPEN test status - Malfunction. No DTC codes are stored. No DIC Lights. Remote Key Fob has been giving a few issues, namely Vehicle will not respond to an Open/Lock command from the key fob. New batteries installed to FOB made no difference, plus on one occasion recently the vehicle unlocked using the Fob, the vehicle started normally via the push button, then a random warning came up on the DIC stating the Remote Key was not found, all this while the key was located next to the central cup holders. Does anyone have any input or advice regarding this scenario? TIA
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
