I do understand the merits of an improvement in dampening but my stock black shocks provide an excellent ride for my purposes. Bilsteins may be a viable option if I was looking to replace worn shock absorbers and level at the same time but the varying opinions on the impact of preload is still a concern.
I am trying to justify purchasing Bilstein or Pro Runner SS levelling shocks when I visit the Houston area at the end of the month (much less expensive than where I live). However, I am not finding compelling arguments that support levelling shocks over bottom of the strut spacers. Another forum member (GMC-AT) has expressed his preference for 1.5" bottom strut spacers on different threads. I would prefer a level that improved function as well as appearance but can't afford to experiment!
Its really isnt a comparison. Spacers do not improve the ride, cause extra wear on joints, limit UPTRAVEL, overextend stock components. A .5" spacer wont be as bad as a 3". A spacer does nothing for performance except lift the truck. A spacer can cause stock shocks to be over compressed causing shock failure. This has been proven time and time again on many make and models of trucks.
A bilstein, regardless of setting, does not limit travel up or down. It will provide extra suspension articulation over stock, allow for full suspension range of motion, improve the ride with better valving and dampening characteristics, allow for better dampening on rough roads as they are monotube shocks vs a cheap twin tube. As they use the stock upper mount, the shock angle is in a better position which will keep the coil from hitting the arm.
I posted a link that answer all of these questions above. PLEASE READ THIS - http://www.bilsteinus.com/fileadmin/user_upload/user_upload_us/pdfs/Bil_LevShks_WebArticle.pdf
Edited by MRT Motorsports
Well stated response. I have read this article several times and am aware that there is potential for bias in favour of the product being sold. However, it does make sense and if it wasn't for comments in this (and similar threads) bashing ride quality at the higher settings, it would be a no brainer for me too!
I've read that too but put a 2inch motofab today and truck looks so much better! Ride didn't change any I can tell. It'll work till I figure out when these 6112s come out and whether they are worth the coin.
I appreciate all of the great information being provided. I want to check my understanding further. When comparing a 1.5" lift by Bilstein to a 1.5" spacer lift, there should be no difference in potential for extra wear on joints or damage from overextended stock components. As I understand, they both extend the coil over shock assembly creating similar new angles and changes to the stock components. Bilstein's design addresses potential issues with up and down travel and is a better quality shock absorber.
I put the bilstein 5100s on the rear of my 14 High Country with a new 2" block a few weeks ago. Ride is unbelievable compared to stock. Liked it so much I got the adjustable 5100s for my front, removed the lower block of my 2.5" RC level , and installed these at highest settings with the top spacer from the RC kit. Ride is incredible. Ride is ridiculously smooth and soaks up bumps great. Highly recommend the 5100s. Best investment I ever made. New shoes this week.
  • Like 6
How far away is the upper control arm from the frame bump stop fully extended? That's good to hear that you can fit a spacer in with the steel suspension. I don't know that you can with the aluminum.
Truck looks great, and happy to hear you are enjoying the ride!
Easily a good 1.25" to 1.5". Plenty of space. I don't off-road so plenty of articulation left there at the base of the UCA.
I put the bilstein 5100s on the rear of my 14 High Country with a new 2" block a few weeks ago. Ride is unbelievable compared to stock. Liked it so much I got the adjustable 5100s for my front, removed the lower block of my 2.5" RC level , and installed these at highest settings with the top spacer from the RC kit. Ride is incredible. Ride is ridiculously smooth and soaks up bumps great. Highly recommend the 5100s. Best investment I ever made. New shoes this week. 7e341c2f884c1880c4469e5a0a0f3d39.jpgc2d124cca87c60ce55033c93e87ded12.jpg476f5b8aec83f56640267f5aa8a06850.jpg
Looks good, this is my plan as well. Just a heads up... Your rear shocks are upside down the boot goes on the bottom on these models
I actually talked to bilstein about that because I was curious too with no install directions in the box. They told me it did not matter with these shocks. They can be installed either way and 90% of installs they do in their test vehicles have the boots up. Their customer service was very helpful. I may have to readdress with my dealer if that's the case though. Edited by bwilloby46
Is anyone aware of a replacement Bilstein (or other brand) shock that will work with the NHT Max Tow package?
From everything I can find so far, Bilstein specifically excludes support for it.
Thanks! Yup I love the ride. It's like a brand new truck. Got new Toyo's ordered today. Dealer tried talking me into rims as well but still thinking on it.
Those shocks will bolt on to the NHT truck, they might not have enough dampening to control the rear spring on the NHT tho.
Per this thread, a few users have bilsteins on the NHT equipped trucks.
http://www.gm-trucks.com/forums/topic/162049-nht-ride-quality/
I had an 08 NHT with z60 suspension that felt like there were no shocks installed. I put Bilstein 5100 shocks in all 4 corners. Problem solved.
Another good NHT info thread - http://www.gm-trucks.com/forums/topic/172318-2015-silverado-nht-suspension-upgrade-help/
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
