On ‎6‎/‎27‎/‎2018 at 11:36 PM, CH15GMC said:
Just ordered the 6112. Look forward to getting them and testing them out. I was going to get .5" spacer for a little more lift. Is it better to get the top or bottom spacer? I'll looking into UCA later.
Will the 6112 have more travel? I wanted to get some 275/65R20 KO2's...should I be concerned? Thanks in advance.
Did your 6112's come in yesterday?
Not yet...MRT said they didn't get the delivery from Bilstein yet and therefore obviously have shipped them out. Getting a little frustrated but I'm sure (hoping) that MRT pulls through and gets this figured out quickly as I'm needing new tires soon.
Arrrgggghhhh…….. the ever elusive Bilstein 6112 for the K2 2014-2018 Silverado Sierra...… :(
If you go directly to Bilstein's website and enter your vehicle information, the 6112 is not an option for our trucks.  Is it still in development?  I feel like I was reading about these shocks over a year ago.
Some websites still list them on backorder for 2014 and up Silverado/Sierra.
MRT has not updated their website since January.
They have been available for the 2015 and up Tahoe/Yukon, but not Silverado/Sierra.
I have often wondered if the Tahoe part number will work on a Silverado Sierra.
Tahoe/Yukon Kit :
Suspension Kit, Bilstein B8 6112, Chevy, GMC, Kit
Part # 47-251922
Make: CHEVROLET
Model: TAHOE
Submodel: LS
Beginning Year: 2015
Ending Year: 2017
Engine Type: V8
Engine Family: Chevy small block Gen V
Amount of Lift Front: 1.800 in.
Amount of Lift Rear: None
Drivetrain: 4WD
Application Notes: Adjustable from 0 in. to 1.80 in.
Back in the 90's when the Tahoe's/Suburbans were basically Silverados with a roof over the bed, I would say it's probably ok.  But their paths have become more separate over the years....I think the SUV's are now even moving toward independent rear suspension and dropping the solid rear axles.  My opinion is to install a part that's been designed and fitted for your truck and not chance it.  Bilstein even tweaks the valving of the shocks for the vehicle so what you buy for a silverado has been designed and tested to support the parameters of a Silverado.  Just my $0.02.
I agree. Was just curious since the lower arm mount is the same.
Bilstein must really be scratching their heads getting the 6112 to work with our trucks.  It has been over 3 years since the tease.....
Yeah it really makes you wonder what issue they're running into.  I will say, my last truck (2007 Silverado) had the 4600 HD's and they were amazing.  The 5100's are supposed to be the same shock but with the ability to level the front end so I'm expecting a similar performance over time and off-road.  I can definitely feel a major upgrade over the crappy Rancho's which I hated from day 1.
My 05 Silverado had 4600's from the factory and they were great.
4600 style also goes back to my factory 2004 Silverado SB Reg. Cab Z71
Yep that was back when Chevy still put quality parts on their "off road" packages including metal skid plates.  My dad had a '96 Z71...that truck was a beast.  These newer trucks look great and have a lot of cool features, but you do have to spend some money upgrading some parts if you like to go off the pavement and play a little.
Have you seen this thread:
https://www.gm-trucks.com/forums/topic/213423-last-good-z71/
Splash shield/skid plate
Same thing
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,277 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
