Curious why you put the check valve on the supply side. I have the dual exit can so I put one on each exit hose and thought about putting one one the supply line next to the exit on the engine to keep anything that was in the hose from going back into the engine. People told me not to worry about. I'm not saying your wrong I was just curious when I saw you picture.
I put it on the wrong side as their instructions were somewhat lacking and it made sense to me at the time. Its not in that location anymore.
I got mine in the mail this afternoon. I'm actually really impressed with the product. In an attempt to keep the hoses short and not worry about the hissing noise, I'm planning on fabbing up a simple bracket off the master cylinder like the RX can uses. Hope to get to it on Friday afternoon/evening.
Found some time this afternoon to knock it out. Longest part of the install was making a bracket. 1400 miles on truck. Almost zero oil in manifold or throttle body.
got mine in yesterday and installed today. im still confused on where the hoses go i have outlet going under the air intake (throttle body) and the intake going to the right side is this correct? iv scrolled though all the posts and iv read it being installed both ways and seen pics of it installed both ways. im just wondering what the correct way is? with the way i have it now iv already picked up quit a bit of oil/water in only 80 mi
Sounds like you have it reversed. Outlet on can goes to right side of engine. Edited by martha3065
Your right that people have it both ways - I believe under the throttle body goes to can inlet
i swapped my lines Thanks
Edited by scottl1346
ADD W-1 catch can parts, I looked into ordering parts from McMaster-Carr, the stainless screens part#2930T24 and replacement orings
part#9464K142.
It looks as though they cancelled my order "due to the complexity of export regulations"
so much for US/Canada free trade!
Do you work for Rainbow Disposal? :lol:
negative. they do pick up my trash though!
I run the shop at a company called calmet services
Awesome
-tapa
Just picked up a Version 1, black on Ebay tonight. Cheapest I could find. What size mesh screens did you guys get from McMaster Carr? They make them in 304 and 316 SST. I plan on using some leftover 3/8" transmission hose I have from Napa. I want to mount it as close as possible to the engine. I'm thinking firewall or brake booster area. Any long term updates on this product's quality? What is the Oz/1k miles people are catching?
Not that I'm a huge tree huger, but what is everyone doing with fluid from there catch can? I've been saving mine in a jug, but l'll need to dispose of it eventually.
^The same thing I do with the 8+ quarts I drain out of it at every oil change. Same thing I do with the 6qts I drain out of my wife's Enclave and the same thing I do with the 5qty out of my 89 blazer. Pour it into my 5 gallon used motor oil container and take it to Autozone and dump into their recycle tank. Advance has it also, most parts stores have a oil bin in the back they let you dump into. I agree that people should not just be dumping all this oil willy nilly. Probably why it's illegal for car makers to install something like this to begin with. Most commoners would probably dump while pumping gas.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
