Just turned 1 week old today... Denali fully loaded 3500 with the Duramax... AMAZING truck blows my F250 away i traded in for this.
What year was your Super Duty?
so almost 500 miles mixed driving city and highway STILL have yet to refill the truck... just under 1/4 tank of gas left...
just got the center console insert
just installed my Backflip Revolver X2
just installed my Backflip bakbox 2
this is the best truck i have ever driven or owned... next weekend hauling my 10K trailer short run see how it does (i'm sure better than my F250 did being a gasser)
good point I left it out... 2016 one of the very first I ordered it August 18th
You must have really hated it to trade after only two months.
That's what I was thinking...
You went from the 6.2 gas Super Duty to the Duramax, I can see why you are impressed.
Just picked this up on Columbus day to replace my '03 Silverado SS AWD. Love this truck!
2015.5 Silverado 2500HD High Country
Added/changed so far:
- Weathertech floor mats and window deflectors
- Recon scanning tailgate light bar
- Fold-a-Cover tonneau cover and tool box
- center console insert
- removed 4x4 stickers
  • Like 4
Beautiful truck. Post pics of your upgrades when you can, I'd like to see that tailgate light.
Nice truck [emoji106]
Here's the completed Light bar.
Parking lights
Reverse Lights:
The light bar has brake lights that are more intense and also have the 'scanning' turn signal lights on each side.
This is my 3rd version of this brand on various trucks now.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
