Just bought this 2015 HD around two months ago. Remove the small mirrors and replaced them with the Trail Ridge tow mirrors. I really like how they turned out.
That truck is 3 years old??? Thing looks brand new.
Yes it is a 2015 and only had 8,500 miles on it. I just could not pass it up. Plus it is the same color as my Harley.
New wheels..Hostile Hammered.  20x9 +10 with 305/55/20.  Shimmed the front bumper (although it might have just cleared), tied back the liners and had to trim splash guards.  Only a slight rub on the passenger side flap when backing out of the driveway at full lock.  I think if I trim a bit of the flap it will clear.  Has a Readylift kit in it but it's still at roughly stock height.
On 11/19/2018 at 2:58 PM, casey.mikl said:
Your truck/trailer look familiar. Were you working the pipeline in NE Ohio this summer?
Just sold my one owner 98 & have gotten my first diesel! Love it so far. 2019 Z71.
Edited by FASTOYZ
Put on some fender flares, new tires flinging crap  on the paint of the truck. Modifying the mud flaps to go back on, rears on here.
Added lights to my step bars.  I love lots of lights...
Looks good. I don't have clearance lights, but will post a pic once I get my LED's installed in the grill (Raptor setup). I've thought about lights by the step bars.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
