Thanks, Yeah I figured there were some sort of disclaimer enabling GM to get away with not having to cover the repair.
I will let you know how it goes.
  • 9 months later...
A friend of mine was a tech at a GM dealer for quite a few years until in the last 6 months or so he switched to Dodge because of a better offer and better management.  None the less when he was at GM he sent me a pic of an oil pump from a 2014 5.3.  The vein in the pump as well as the outer ring were both cracked..... said it was pretty common and they were doing one or two trucks a week for quite some time.  Not my cup of tea lol.
Edited by SierraHD17
I dont know why on earth they would change from the old style pump in the pan.Its proven to work leave it.
Thanks for the insight!
Good to know
G.M Is now installing a new engine.They were going to just do crank, bearings and oil pump but apparently found more damaged parts.
I'm a tech at a gm dealership. I personally have done 20+ oil pumps on 5.3 and 6.2 ecotec3 v8's. Starts out as a powersteering pump type noise, then gets louder until they catastrophically fail. Poor design, outer race in the pump that the veins ride on has a thin spot where it pivots on a pin. Race cracks and the veins hit the ridge. I've seen pumps fail as early as 7k miles. There is a tab for the issue. Sometimes it will set code p06DD for oil pressure control solenoid.
  • 6 months later...
Yes! 2015 Silverado 5.3L, for about a week now, the truck had a whining noise like the old GM power steering pumps. I have been monitoring the transmission fluid temps, and oil pressure on a constant basis. About a mile from the house warning lights came on that said no oil pressure, and watched the oil pressure gauge go from high to 0. I shut her off immediately, the dealer out of Antioch sent a wrecker down to bring her back to the shop. Thank the lord we purchased extended coverage, currently 46k miles.  I’ll keep everyone posted next week.
UPDATE: our pump did fail, I asked the service person if they had any other complaints, she responded yes, there is a 2016 out there that has the same whining noise, and GM will not let them replace until it fails. I must say we did get excellent service, and the free use of. 19 z71 Silverado that we fell in love with.
Edited by Bob Art
Update
My 2018 Silverado 5.3 just had a oil pump failure with 12000 miles. What tab are you referring to?
So I just had my oil pump repaired by way of a new motor. After they fixed it they called me and told me I have 2 bad injectors caused by this issue. The motor was covered under warranty but they are telling the injectors are coming out of pocket. Shouldn't the failure of the engine cover this issue? Also how does a truck that never threw a code have 2 bad injectors right after they replace the motor. Does this sound fishy to anyone else?
So they replaced the motor and used the old injectors? If yours was rebuilt I tell to check the codes. There wasn’t an injection problem until you messed with it.
Yep pretty much. Waiting on them to open this morning pretty much what I am going to say. Being as polite and respectful as possible.
My oil pump went on my 2014 with a  4.3.GM installed new engine and when I got it back it had a code saying injector issue.Sent it in for them to look at and when they told me it was gonna be on me I told them forget it.Brought it home ran 2 bottles of sea foam through 2 full tanks of fuel and havent had the code or any issues yet.That was 20,000 klms ago.
Well to close my part of this thread, summary GMC Excutive Customer service told me I was not a priority customer and they would not be assisting or covering in the repair. (First time purchase of a truck and probably gonna look else where for my next one) Long story short pay to fix this or remove it from the shop. This is just after close to month of my truck in the shop. They did cover the motor and the labor for that but the injectors are not covered. Well good luck out there with them.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
