It's the little things...
...after enabling the function in your radio settings, you just unlock truck as normal and press unlock again and hold five seconds. The windows will go down after that.
And here I was thinking that this feature wasn't available. It's not in the manual (that I could find) but sure enough the setting is there. Turned on the feature and it works like a charm. Thanks!
  • Replies 53
That's the brilliance of this site. I didn't know it exsisted either until a member explained it to me. So I'm super glad you figured it out.
"On some models, press, release and then press and hold unlock to open all of the windows.
Pressing the button again will stop the windows."
(page 2-5 of 2015 sierra manual)
Unfortunately the feature is turned off by default from the factory. You have to find the feature in the settings to turn it on, and I don't believe those directions are found in the manual. Don't have the manual at my fingertips at the moment, though.
Little cons:
-No dome light switch/single function.
-Radio is a screen and not a radio.
Little pros:
-Trailer brake controller is awesome.
-Cloth interior is fantastic compared to GMT 900
-Wide angle mirror blip in driver's side mirror.
I second the rear air vents! Keyless entry and engine start would have been a nice touch from GM too!
Mine has both
When my truck had 250 miles on it, I replaced the rear cargo light bulbs with LEDs- when I removed the cargo light housing, the paint was scratched to bare metal in three places- 3 of the 4 corners had eaten through.
I can't really fault GM for the paint though. It's the damn EPA.
While I agree that waterbourne paint is causing problems for all makes, you shouldn't hate on the EPA too much. Just google some images of smog in China to see what life is like without anti-pollution regulations. At least we can go outside without a mask.
For $40-50k, a truck could be painted with multiple coats like the German luxury brands do, and the paint would be OK.
My bluetooth decides when it wants to work, sometimes it just unlinks my phone and relinks during conversations. The back up camara staying on for 10 seconds after I put it in drive makes me sick too haha.
Get your truck back to the dealer for the IntelliLink updates. I had some real quirky issues with mine when I first bought it and the huge April update straightened a lot of it out.
No one touch up for passenger window
Paint is "soft", scratches and chips way to easy
No rear vents
Headlights are pretty bad
Truck looks awesome though!
Headlight update available for the earlier build trucks. Go see your dealer, ask about PIT5374. Software flash will increase voltage and they will install Vosla bulbs. Not perfect - but much better.
You can't point the finger of blame solely at the EPA. A) We elected those morons in the first place, so we have to shoulder that portion of the blame and B) they're kind of protecting us from ourselves - without some of the regulation, things would be significantly worse than they already are.
For $40-50k (WHAT I PAID), a truck could SHOULD be painted with multiple coats OF REAL PAINT like the German luxury brands do, and the paint would be OK NOT BE WATERCOLORS
Or, I could sand it and repaint it myself with actual paint like they use in our luxury-themed southern neighbor, Mexico.
Could you, do you have those skills? It's a rare skill to have if you don't have a paint shop, and if you do, you're required (or soon will be) to use waterbourne paint.
Once the small shops are converted over, it will even be hard to find the solvent-based paint. Who would supply it? Just like lacquer, try to find automotive lacquer today.
(And note, Germany required waterbourne paint before we did.)
I am so sick of taking this thing back to the dealer. They still can't even get my transmission to stay in gear.
Little cons:
Little pros:
Not sure what the dome light thing is. Mine has a rocker switch up top that says "on-door-off", so you can turn it off.
I've had my truck for all of 3 days, but already found some annoyances.
1. Why can't I turn my cargo light on while I'm in drive? I like to check my load from time to time.
2. Why didn't they put my current speed on the same screen that shows the speed limit in the dash cluster?
All in all, awesome truck, just those couple annoyances for now.
1. Being in D is not the limitation - it's moving forward over a certain speed (10MPH?)
Do you know how many times I've driven behind idiots with their cargo lights on and shining in my face? I'm guessing this is either a DOT reg that it's not allowed to be on while in motion, or GM took the proactive step.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
    • Good for you and her!   Lots of brushing and grooming to be done
