I just want to add to all of this:
From day one, as soon as the CAI was mentioned I got on the phone with K&N and they were 100% with me through the whole ordeal. They flat out said, if they prove our product hurt your motor we will fix your motor just the same as the dealer, if they cannot prove it and wont fix it, our attorneys will have a field day.
Also, when the truck was fixed and they were refusing to re-install my CAI K&N even offered to buy back my CAI for full paid price if I chose to go back factory. Of course I chose to keep the CAI.
But K&N stood behind their product, beside me and made me a devout customer for life.
They even sent me a whole new filter as the one that was in the truck when the engine went was plastered with oil. They said, just in case you cant get the original filter clean heres a new one.
That is customer service.
Glad there are still companies that will stand behind you these days and go above and beyond anyone's expectations
Edited by rdnckhntr94
  • 3 weeks later...
I just picked up my truck. It stalled out one day backing out of the driveway and then almost died pulling up to a light. Took it to the dealer for that and other issues. 8 days of driving a rental truck. I go get mine. Scratched up everywhere and they had done nothing because they said it was tuned. I never tuned because it is the one vehicle that I don't have to fix this way. I was shocked. They then said they could flash it to stock. I didn't know what to do so I let them do their thing, but I don't trust my dealer service now either. I'll see if they will actully fix the paint damage soon and hope I never need a motor since they are already saying it's tuned with there being no big issue. Glad to hear K&N step up. Might have to get their intake so they help me later.
Sent from my SM-N920V using Tapatalk
Ok, I just saw your post on the other thread too. If I was in your shoes there would be two things I would do.
1) Try to have a meeting face to face with the Service Department Manager so he can explain why it took 8 days to let you know they would not be working on your truck.
2) Tell them to prove to you that it was tuned.
If that doesn't work than there is;
3) Get in contact with local lawyer to help you out.
Today was the first time really driving it and the flash to stock they claimed made a change. I drives just like new now and is kicking to V4 more again. It hasn't done this since they false neutral fix for the transfer case the dealer did at 6150 miles. So, that tells me they screwed something up when they did it. Another recommended another dealer and that is what I'm going to do after these guys fix the scratches they put in it for me.
  • 6 years later...
On 4/10/2015 at 6:06 PM, nomadicdogg said:
Any one with a 6.2 have issues with their engines going poof lol
my truck has 19000 miles on it. going down the road, went to reduced power and within about 15 seconds grenaded. Had oil pressure and normal temps until it went. Pieces of piston ended up on the back of my trailer, trailer was empty, no weight on it and crusing at about 50mph 2000 rpm roughly?
toasted. If your engine went PM me.
Just had this happen to me on Saturday 9-24-2022 in my '14 sierra denali.. although my truck died on the side of the road, no oil under the truck, or smoke before it happened. Towed it to dealership, they got it started and that's when the rod went. Photos taken by service tech at Beaverton GMC in Portland, OR
  • 3 weeks later...
3 hours ago, pokismoki said:
damn, you 6.2 guys need to retorque those rod bolts.. or did the rod bolts still remain intact durring failure???
I'm not sure, all I did was buy the truck lol GM is sending a new motor now.
  • 1 month later...
The valve spring on my failed at 120K miles but like you said it didn't drop the valve.  So it was actually a esay fix once I got the truck towed back to my house.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
